Soft purge line??
Old Jul 13, 2008 | 05:44 AM
NOTFAST's Avatar
Default Soft purge line??
Do I have to be picky due to pressure with attaching a soft line for the purge? Or will pretty much any tubing from the autoparts store work? Kind of doing something similar to the dynotune purge set up....
Old Jul 13, 2008 | 08:01 AM
sleeperstyle's Avatar
soft purge is fine if you are cheap like me. get a small piece of pipe with the right threads for the purge on it. looks horrible but works 100%. function over fashion when you don't have $ to **** and burn.
Old Jul 13, 2008 | 10:13 AM
BAKED's Avatar
Make sure whatever you get is made to handle that much pressure.
DO NOT use rubber hose, vacuum line, etc.
Old Jul 13, 2008 | 10:52 AM
NOTFAST's Avatar
Well thats my question...LOL...what specific type of hose/line do I need?
Old Jul 13, 2008 | 11:36 AM
BAKED's Avatar
You can go to lowes and get the milky white colored tubing, just ask one of the salesmen what can withstand high pressure (1200+psi)
I think all that the auto parts stores would have that you can use is copper.
Old Jul 13, 2008 | 02:28 PM
myfast70's Avatar
Air brake hose will work too
Old Jul 13, 2008 | 04:58 PM
NOTFAST's Avatar
Couldnt find anything in my trips today. Salesman at Home depot said I need to find hydraulic hose....
Old Jul 13, 2008 | 05:54 PM
BAKED's Avatar
Not for the purge you don't. The milky white, hard plastic line they sell will work. I think it's the same stuff you would use to hook up an icemaker on a fridge LOL
It may me nylon tubing.
Old Jul 13, 2008 | 06:06 PM
NOTFAST's Avatar
I looked at that stuff. its identical to the tubing in the dynotune purge kits, but its only rated to like 55-70psi...hmmmm
Old Jul 13, 2008 | 06:11 PM
SuperSlow02's Avatar
I bet being an open end tube will releive alot of the pressure.
Old Jul 13, 2008 | 06:23 PM
VIPRETR2's Avatar
Matt, I don't know if that Home Depot stuff will work but there is a hydraulic hose place called Cauliflower on Pulaski Highway in White Marsh that will have anything you ever need. Did I see you coming out of White Marsh mall around 5pm today? I was gonna call but didn't have my phone on me.
Old Jul 13, 2008 | 07:00 PM
BAKED's Avatar
The home depot stuff will be fine for a purge, I've used it many,many times with no problems. Hydraulic stuff is way overkill and cost alot more $$$
Old Jul 13, 2008 | 07:52 PM
NOTFAST's Avatar
I guess it can't hurt to try the home depot stuff....its cheap enough.
yeah that was me...I didnt see you. Had to drop off a tux....
Old Jul 13, 2008 | 08:00 PM
Mike@HSW's Avatar
you dont need anything rated 1200 psi. Its not like a main feed line that is under pressure. if the end of a purge line were sealed then yes you would need a material designed to handle that kind of psi. When it comes to purging its just an open line, so its not actually containing that kind of pressure. I would use something slightly rigid, we use flexible aluminum tubing in our kits.
http://www.harrisspeedworks.com/shop...cat=263&page=1
Old Jul 13, 2008 | 09:28 PM
JoeyGC5's Avatar
Dynotune kits use 1/4" Poly line, which is available at any home/hardware store.
Old Jul 14, 2008 | 07:03 AM
Nitro Dave's Nitrous Outlet's Avatar
If you want something a little better looking we introduced our purge systems a few years back with alluminum purge tubing. We flare the ends and put a B-nut and sleeve on it for rigid mounting. We sell this tubing seperatly.
It comes standard in 3ft however if you need it longer we can make it longer.
http://www.nitrousoutlet.com/catalog...roduct_id=2883
Dave
Old Jul 14, 2008 | 08:13 AM
jmill96Z's Avatar
This is the same stuff I used forever. I've bought it from Ace hardware, TSC, Home Depot. It's cheap too. Make sure you don't buy the silicone stuff from Autozone.
Old Jul 14, 2008 | 07:41 PM
chvyboyls1's Avatar
I don't remember the exact size but I used a piece of hard brake line 6" long off the solenoid and then medium strength plastic air brake hose to the wiper cowel. The plastic line was about the diamater of a pen or pencil. This worked excellent and was great for the fast sneaky purge when sneekin on some one. The larger line dumps any air in a split second rather than the typical 3-5 second purge.
Old Jul 14, 2008 | 09:22 PM
transam69230's Avatar
I used brake line from autoparts store, rented a tube bender from autozone and bent it up to the cowl off my purge.
