AFR question
Well, it is a direct port wet kit so i should be getting more fuel when it counts, but I agree with you. I'm just trying to figure out the most cost effective way to manage the AFR. I don't want custom tuning on a dyno because I don't run the NO2 all the time and tuning software like LS1edit is expensive. I want to adjust it on the fly when I'm at the track.
Cap'n: Looks like you are just bolt-ons from your sig, correct? We can just forget about the nitrous for now and try to diagnose what's going on N/A. The first thing I would think is the fuel pump. An aftermarket one would definitely not hurt if you're planning to spray up to 180. Cleaning or replacing injectors would be my next thought.
99 FRC
Tell me, have you ever used or seen the MAFT product (link below)? I'm thinking this is what I should have purchased rather than the Timing Tuning I installed. Looks like it can control both timing and A/F.
http://www.maftpro.com/
99 FRC
99 FRC
How was your experience with LG? Did the tune cost you an arm and leg or just the arm?
I bought their headers, so had it done at the same time. So, when you got the results above, did you have the stock program or the power program in?
