lowest activation rpm
i have a nitrous outlet window switch and i wanted to see what is the lowest rpm i can set it to and still be safe. its at 3000 right now like most people but can i drop it any more and be safe
Generally you dont want to spray under 3000. But I used to do it all the time on my 97Z. Not saying that it is safe I just didnt know any better back then. When you spray under 3000 you run a higher risk of a nitrous backfire.
What gator's 99TA said, and most likely brake rods and ring landings as well. You are putting extreme load on the crank rods and pistons and transmissions & rear ends. Nitrous make ungodly amount of torque . When the motor is up around and above 3000 rpm's its freeing up torque and when adding nitrous it don't over load the torque and brake parts, Unless you build a motor with the best parts money can buy. Plus at low rpms you are in danger of having a nitrous back fire from the cam not spinning fast enouth to close the valve do to a slite bog off the line
