Nitrous tuning advice for 175+shot.
Old Aug 1, 2008 | 01:09 PM
nahasapeemapetalon's Avatar
Originally Posted by JL ws-6
My car's 3330 with my 280 lbs in it, so you've got plenty left. How much of it I would take out of a street car, that I dunno though. Without sacrificing safety/comforts, you're not gonna get a ton lighter that I can promise.
I know. Just have to make more power right?
Old Aug 1, 2008 | 01:49 PM
Danger731's Avatar
where do you get a 4000 lb trans am !, you got 15 inch subs or after market electronics ?>
Old Aug 1, 2008 | 02:38 PM
ShiznityZ28's Avatar
Mine was 3500 on the 8.9 pass.
Old Aug 1, 2008 | 02:49 PM
The only weight reduction I have done is taken front sway bar out for 3920.
It has a/c, subframe connectors, ford 9", 4l80e and two nitrous bottles in it.
No speakers or anything like that. Everything else is stock.
Thats with me in it so the car is only 3700lbs.
Old Aug 1, 2008 | 03:34 PM
OutlawZ's Avatar
JL is just about right although we always start with the na tune that runs the best MPH( timming and fuel wise) this gives you a good base. then we use the lb/hr of fuel methode for a given nitrous jet. it will get us to within 5% normally first time. I don't want to scare anyone with our AF but its over 12.5 even on a 300 hit. But like i keep saying te plug will tell you. A world class nitrous guy showed us this and it has worked great this year. ATV has went a better mph than ever on 1/2 the nitrous. and .5 faster on the same shot as last year.
More good knowledge in this paragraph than probably 50% of the posts in this forum..... JMO.....
People are starting to come around to the theory that super fat tunes can destroy motors.... Also people stick to the 2 degrees for 50hp and call it a day but you have to see what YOUR motor likes. My motor made more power at 32 degrees base timing than 34 or 36.... I would have set it at 36 and called it a day if I tuned it... My tuner knew better.... So if I had my timing at 36 and retarded my timing 8 degrees for a 200 shot I'd be at 28 degrees..... Easily enough timing to kill the motor..... I use a 2.7-3.1 degrees for 50hp baseline..... So now my 200 shot with my base 32 degrees becomes more like 21 degrees..... Difference of 7 DEGREES!!!!!! Keep the A/F's in a reasonable zone and NEVER run alot of advance.... I think new guys should be restricted to pulling 3 degrees per 50hp or they can't buy a nitrous kit...
Old Aug 1, 2008 | 04:00 PM
JL ws-6's Avatar
Race your car!
My motor tune was set up for a 105 unleaded **** fuel because that's what I tried to run it on initially, so the thing only ever had about 21 degrees of timing in it because of that. I put 116 in it even with the timing down and it picked up .2 and 3 mph, never tried any more timing, but I know it would have taken it.
We took 5 degrees out for the little plate kit, I've had it jetted at 100, 125 and 150 and the plugs don't even start to show any color or anything until I put the 150 jets in it. And it's still way safe, I can run the same plugs all day if I want to because they're not getting any heat.
Starting off safe, with more timing pulled then needed, more octane then needed and a colder plug then needed is never a bad idea. I hate to tell anyone to leave a #6 plug in a car with a 150 shot or more, I know there are people doing it, but I would never take a risk like that, it's just not worth it.
Old Aug 1, 2008 | 04:16 PM
OutlawZ's Avatar
i'm running 110 octane race fuel right now for the 150 and 175 shot..... after that only C16 will go in the tank.
non projected plug, pulling about 3 degrees per 50hp and shooting for about a 12:1 AFR on these small shakedown shots...... I'm keeping the shots low while I get used to the car and making my licensing passes for 9's.... going 10.60 on motor doesn't give me much room for going crazy on jetting while making my NHRA license passes....
Old Aug 1, 2008 | 05:21 PM
vette_c6's Avatar
i am glad that every body here in an Nitrous expert
well here is my stuff
Wisco Pistons -3.2 Flat Bore 4.005 ( same stock LS2 )
COmpstar Connector the one in speed inc
headers Long tube 1 7/8
FAST 92
With ZEX WET SYSTEM
which is will be inside the FAST
patriot heads
Combustion Chamber: 59cc
Intake Runner: 227cc
Exhaust Runner: 70cc
Intake Valve: 2.055"
Exhaust Valve: 1.57"
Max. Valve Spring Lift: 0.650"
Heavy duty Oil Pump Melling
JP LS2 Single Roller Timing Chain Set
Underdrive Pulley SLP
Haltech intake
but i didnt buy my Camshaft yet ,,
my piston compression will be around 11.7
got any idea how much i can make N/A ?
and how can i orginize my camshaft ?
the other thing is what should my Ring piston space be ? i mean when you take it around the piston i shouldnt make them close to gether in the end ( i guess ) so what should the distance be??
sorry for the language guys ,, i am foreign
Old Aug 1, 2008 | 07:40 PM
jetblast's Avatar
Everyone repeat RICH IS NOT SAFE!!!
how much timing did you take out, if any, with the 12.5afr or did you keep the same timing that you had when you ran richer?
Old Aug 2, 2008 | 11:55 AM
You definatly need to pull timming we started with 5 degrees on a 150, 9 on a 225 and get the a/f correct on the plug along with the heat range. then slowly add timing until it starts to slow down while watching the plug. the nice thing is the fast can add .33 deg at a time.
But be carefull timming won't hurt you until the a/f is close then it can hurt parts fast.
Old Aug 6, 2008 | 05:28 PM
Bucktooth's Avatar
I just got tr7 and tr8 plugs, and they are projected tip plugs. Is this what you guys use? I have heard non projected tip plugs are the way to go over 175???
Old Aug 7, 2008 | 06:09 AM
  #32
vette_c6's Avatar
question about the AFR
do u increase the AFR because you are using Plates for nitrous ? or because you must ?
i am using Direct PORT
which is mean 8 fogers for each piston ,, does that mean i also have to increase the FUEL ? and what should my AFR be ? 12.00 ? 11.5 ?
before when i used to use the magnacharger it was 11.8
what should i put now ?
thanks
Old Aug 7, 2008 | 07:24 AM
  #33
JL ws-6's Avatar
Race your car!
The nitrous system is going to add fuel when it's on, but I'd aim to get your motor tune around 11.7 give or take as a starting point. That's about where you want to end up anyway with the nitrous.
Old Aug 7, 2008 | 07:53 AM
  #34
thanks
We have 2 cars a plate car and a DP car(atvracer's) The one were racing right now is the DP.
We run around 12.5 on a 325 hit. but the number means less than the fuel ring on the plug.
