Lets see you Nitrous Switch Panels
Old Aug 22, 2008 | 01:01 PM
MYSTIC-1SC's Avatar
Default Lets see you Nitrous Switch Panels
I really am having a hard time deciding which switch panel to buy, but really like the looks of the one Nitrous Outlet sells that mounts right where the cubby hole and cigarette lighter are on the camaro center console.
Old Aug 22, 2008 | 06:00 PM
SuperSlow02's Avatar
have you seen nathans or mine? either that or HSWs new panel or a Beers custom
Old Aug 22, 2008 | 06:11 PM
DiabloFormula's Avatar
Here's my old setup....
and my new setup.....
Old Aug 22, 2008 | 07:06 PM
Nauty99SS's Avatar
heres mine
nos energy drink lid painted black and taped to the cig-lighter
Old Aug 22, 2008 | 09:50 PM
Mike@HSW's Avatar
here are some of ours .....
http://www.harrisspeedworks.com/shop...cat=316&page=1
Old Aug 22, 2008 | 09:53 PM
SS1875's Avatar
Originally Posted by Nauty99SS
heres mine
I like that one....makes me want to change.
Old Aug 23, 2008 | 04:11 PM
lee20ss00's Avatar
Default heres mine
http://viewmorepics.myspace.com/inde...mageID=4191568
Old Aug 23, 2008 | 04:40 PM
camarojunky74's Avatar
wow some nice setups, kinda hard to see thru all that dirt, some of you need to wash your car.
Old Aug 23, 2008 | 07:47 PM
Datzneat's Avatar
Thats mean.
Old Aug 24, 2008 | 06:21 AM
Beer99C5's Avatar
Just for idea's of what can be done with panels, here are some of my F-Body favorites, all of these are guys from this forum that came up with all kinds of cool ideas...
Lythropus, a wiring genius, using one pressure gauge for three different applications...
Armyman's with throwing in a Lock and a Dynotune guage with standard Nitrous Controls
Bottlefed Making noize with the cutouts, two stepping and staying cool all at once, with the ability to change the tune on the fly
Havoc in case he loses his keys...
Standard gauge with basic controls
Above, Seven Switches without cutting the factory console
Armrest panel for 2 Fast
Old Aug 24, 2008 | 08:06 AM
1999TransamWs6's Avatar
Never put labels on them but it will have labels when the new set-up is done
Old Aug 24, 2008 | 09:23 AM
Tally TransAm's Avatar
damn theres some nice stuff in this thread. im lazy and have one toggle switch mounted in front of my shifter, arming and heater wired into one and no purge.
sometime in the next millennium ill add a second stage and make a nice panel cause im jealous of some of the pics above
Old Aug 24, 2008 | 09:32 AM
99FormulaM6's Avatar
where does everyone get the text added on to their panels?
I was thinking about buying one, but making one cant be too hard. Its just ABS plastic isnt it? then cut it to fit and shape it, add switches and thats it, right?
Old Aug 24, 2008 | 11:21 AM
Beer99C5's Avatar
Most Laser engravers can do it. If you make a prototype and take it to a laser engraver (sign shop) they can probably make ya one, however what they charge will probably be a function of how busy, and how interested they are in doing it.
Time wise, your probably better off getting one premade from HSW, Nitrous Outlet, Dynotune, or Tick Performance.
Old Aug 24, 2008 | 01:59 PM
MYSTIC-1SC's Avatar
definetly some nice setups here. I just purchased mine from nitrous outlet
Old Aug 24, 2008 | 07:06 PM
bad6as's Avatar
ok, what about the wiring part of the panels?
mine only has 3, arm, purge and heater.
the purge only has 2 wires to it, the switched 12v and then the other side goes to the relay.
and the arm and heater each have 3 one to relay, switched 12v and ground.
but i have a queston on the switched 12v and ground. can i loop them like this? or should i run a wire to each? same with the battery to relay this ok to do it like this?
Old Aug 24, 2008 | 08:09 PM
Beer99C5's Avatar
"Y" ing the wire works well and tidy's up what would likely be a rats nest of wires.
Red is a + run
Black is the ground
Center is to the accessory
Old Aug 24, 2008 | 08:50 PM
THENASCAR's Avatar
wow, some damn nice setups. excellent work guys
Old Aug 24, 2008 | 08:54 PM
bad6as's Avatar
can i do the same for the 12v power wires from the relay to the battery?
have a 10g wire off the battery then tap the 3 10g power wire with built in 30a fuse then to the relay
Old Aug 24, 2008 | 09:31 PM
MYSTIC-1SC's Avatar
definetly nice panels, lets see some more
