Lets see you Nitrous Switch Panels
Old Aug 24, 2008 | 11:30 PM
DopdBrd's Avatar
Well I'm gonna have my work cutout for me this week, you guys have just inspired me to rewire and redo my switch panel.
Along with a clutch swap, tranny rebuild, dual cutouts, ABS delete, Line Lock, and dynamatting the entire interior.
Old Aug 25, 2008 | 05:53 AM
Beer99C5's Avatar
Originally Posted by bad6as
can i do the same for the 12v power wires from the relay to the battery?
have a 10g wire off the battery then tap the 3 10g power wire with built in 30a fuse then to the relay
Here is what I did for from the battery to relays:
Got a fuse panel from the local auto parts, the first one was just a fuse panel, I later found one similiar but also had a ground bus (that one is pictured)
10 Guage wire + from the factory "fuse relay center" (there was a hot lug inside it); to the fuse panel I added. Then the relays put to the + Fuse Block lugs on the panel I added.
Here is my diagram
Old Aug 25, 2008 | 06:42 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
Damn Beer your work never cease to amaze me!
I love this one!
Dean
Old Aug 25, 2008 | 05:02 PM
wolfy's Avatar
Originally Posted by Beer99C5
Armrest panel for 2 Fast
you have any pics of that installed? i really think i'd like something like that, but i's like to see how it sits and looks in the console...TIA
-wolfy
Old Aug 25, 2008 | 05:17 PM
Beer99C5's Avatar
Not yet, he was supposed to send me pics. Being he has not complained I assume it fits OK or he has not put it in yet LOL.
Old Aug 26, 2008 | 03:50 PM
bad6as's Avatar
beer what gauge is the red wire?
Old Aug 26, 2008 | 04:25 PM
Beer99C5's Avatar
I forget I think 16-18. Call one of the vendors Nitrous Outlet/HSW/or Dynotune and ask what Gauge to use for switch wiring.
Old Aug 26, 2008 | 04:37 PM
Cthulu's Avatar
here they are! now answer my post!!
https://ls1tech.com/forums/nitrous-oxide/975671-key-power-source-10ga-oj-wire.html
yeah it's ghetto, but it's out of sight.
DopdBrd's Avatar
So when you wire in all your switched 12V in wires like that, how do you fuse them??? I just didn't think it was a good idea to wire them all up to ONE wire like that. If it is ok then I know that will clean up A LOT of my install.
Old Aug 26, 2008 | 04:40 PM
Cthulu's Avatar
I wire them all up to one and put a 4amp fuse in, it's unnecessary as my switches are rated for like 30 amps, but it protects my window switch I guess.
Old Aug 26, 2008 | 04:46 PM
DopdBrd's Avatar
So you use a single 16-18 Gauge wire that runs current to all of your switches and then you place a single 4 amp fuse in-line for your 12V switched power source?
I guess if you use relays for all of the accessories then you really wouldn't have to worry about it.
But is this still right?
Old Aug 26, 2008 | 05:00 PM
  #32
Beer99C5's Avatar
In my case there is a fused switched pigtail (ducted tape ready for use from the factory) in the passenger footwell of the C-5 that has a 20 amp fuse to it. I just spliced into that wire and it powers everything on my panel. Most of it is control stuff, less than 1 amp.
Dry Arm---relay
Wet Arm---relay
Purge---relay
Line Lock---direct to solenoid
Opener direct to Opener (no relay)
Wideband- Power and cal switch
Old Aug 26, 2008 | 05:01 PM
  #33
Cthulu's Avatar
relays need like no power to switch the main line to on..but they need a LOT of power to power accessories...they have an activation lead and a ground..then a main power lead and the line going to what needs to be powered.
But nobody seems to get power for the relays from under the dash...44 view no answer!!
https://ls1tech.com/forums/showthread.php?t=975671
Old Aug 26, 2008 | 05:06 PM
  #34
DopdBrd's Avatar
Well, I'm re wiring the kit this week. Damn this should really clean up the wiring mess.
Old Aug 26, 2008 | 06:30 PM
  #35
TRMIN8R's Avatar
Here the switch panel/gauge pod I built...
easy button is the purge
Old Aug 26, 2008 | 06:44 PM
  #36
Cthulu's Avatar
looks good..
Now answer my post! *shakes fist*
Old Aug 26, 2008 | 06:54 PM
  #37
bad6as's Avatar
lol they looked like 12g in the pic. now wonder i couldent fit two of them in to one connector. ill have to take a picture of mine to see if you guys think its ok
Old Aug 26, 2008 | 09:07 PM
  #38
SuperSlow02's Avatar
easy button FTMFW!
Old Aug 26, 2008 | 10:39 PM
  #39
MYSTIC-1SC's Avatar
wow, this turned out to be a good thread keep the pics coming.
Old Aug 27, 2008 | 06:55 AM
  #40
16again's Avatar
I used 14ga wire on my panel.
Panel in my Corvette that Beer made for me.
