NX jet size info needed
Old Sep 7, 2003 | 09:37 PM
CAT3's Avatar
Restricted User
Default NX jet size info needed
Ok, need to know whats jet size for 175, and 200 shot on an NX wet kit.
TIA,
73/41
Charlie.
Old Sep 8, 2003 | 01:54 PM
Drew778's Avatar
Default Re: NX jet size info needed
ttt
Old Sep 9, 2003 | 10:14 PM
ANIL8U's Avatar
NOS Fuel
73 38 175 Shot
78 41 200 Shot
These are from NX!
Old Sep 9, 2003 | 11:05 PM
CAT3's Avatar
Restricted User
Humm, well then I was running a detuned 175. So maybe next step is the 200! Or I might be iffy and try a 75/42 or 76/42.
Got race gas will spray. I checked plugs after every run and they looked good, i mean actually looked like a normal plug, so i think i may do it this saturday.....200 on a stocker...bottom end/trans/rear!
Old Sep 10, 2003 | 06:10 AM
redsscamaroboy's Avatar
Good luck.
Old Sep 10, 2003 | 10:52 PM
CAT3's Avatar
Restricted User
Thanks Red!
Old Sep 10, 2003 | 11:43 PM
Drew778's Avatar
May the force be with you :p
I'm sticking with a 50 shot, well maybe a rich 150 same thing
Old Sep 11, 2003 | 12:07 AM
CAT3's Avatar
Restricted User
Youd better be there sat..comeover early we get the race gas together, make a couple runs, you can try the tires then we go home after nailing 10's together!
Old Sep 11, 2003 | 03:14 AM
35th SS's Avatar
I got to see this.wish you all the luck Cat.Reckless aka Todd would be proud of you.
Old Sep 11, 2003 | 08:24 AM
99 1LE SS's Avatar
200 on a stock drivetrain wont be a problem as long as your fuel pump can keep up. I was spraying 175 to a stock drivetrain without any problems but 1 time it went lean (fuel pump couldnt keep up)and i killed an intake valve and a pushrod. No other motor damage done and i still drove it home 60 miles on 7 cylinders after running a bunch of 10 sec passes..
Old Sep 11, 2003 | 09:03 PM
CAT3's Avatar
Restricted User
I think it wil handle it, like has been said for years...as long as the fuel is there, and the knock is not!
