NX Console Switches Question
Old Sep 8, 2003 | 09:10 PM
jaywoo's Avatar
Default NX Console Switches Question
Quick request, does anyone have any pictures of the NX console siwtches (part #15896) That Tbyrne sells? I'm going to order these and was looking for some install pics. Thanks!
Old Sep 8, 2003 | 10:26 PM
RJF's Avatar
RJF
Default Re: NX Console Switches Question
here are some on my web site web page
Old Sep 8, 2003 | 10:35 PM
jaywoo's Avatar
Cool, thanks for the Pics! That's where I'm mounting the bottle also, but it's a 10#, not a 15. That 15 looks like it just barely fits, but nice to know if I want to switch to a larger bottle I can. It looks like the switches were pretty much made to fit in the cubby hole spot, that's why I wanted them. Thanks again!
Old Sep 9, 2003 | 02:55 AM
RJF's Avatar
RJF
well not really they moved around some so i some weather striping and put behind the lip of it and made a tight fit and it dont move around anymore.I can get you a pic of what i used unless u kow what i mean
Old Sep 9, 2003 | 09:37 AM
Nitro Dave's Nitrous Outlet's Avatar
If you need to tighten up the fit take some electrical tape and wrap around it with a piece of paper clip under the tabs.Sounds getto but works great and you can not see it.
Dave
Old Sep 9, 2003 | 11:01 AM
jaywoo's Avatar
Thanks for the tips. Hopefully I'll have everything in within the next two weeks to do the install.
Oh, another question, since there isn't much info available for these switches. I figure the first switch on the left is the "arm" switch, the second for the heater. Can the third switch be used for the purge? Is it spring loaded by any chance?
Old Sep 10, 2003 | 08:06 AM
slow's Avatar
the standard NX switch panel is,
SPDT lighted (up arm, center off, and down heater)
middle one is SPST momentary, (purge)
and 3rd one is DPDT momentary, for remote bottle opener.
Works great if you have arm, heater, purge, and remote opener.
if you need a custom switch configuration, other than what NX sells, I sell custom versions of these panels for less. e-mail me. Ryan212@aol.com Or search ebay (nx switch)
I find that either 15 wraps of electrical tape work great, or better yet, a piece of 3/16" weatherstriping wrapped around the panel makes it a perfect fit.
Hope this info helps, and you have a PM with more pics.
Ryan.
Old Sep 28, 2003 | 05:02 PM
98RaptorTA's Avatar
I have the Pics on My Heads and Cam Install Site. Let me know if you want to see in person. I will be back at the Shop the 6th, or give me a buzz at the number on my post at LRRS.
