Changing Plugs
Old Sep 28, 2008 | 01:05 PM
BOLO's Avatar
Default Changing Plugs
Mods in my sig. How often should I change the TR6's?
Old Sep 29, 2008 | 10:07 AM
Stroked96Bowtie's Avatar
I change mine about twice a year. I didnt start running NOS till recently though so I'll be at least checking them more often. Its not a drag only car either...pump gas street/strip setup.
Old Sep 29, 2008 | 10:18 AM
Nick@HSW's Avatar
How often do you spray? There are really two factors at work here, first being the rapid heat rise in the chambers when using nitrous and the second being the fowling out from driving. Once they get the fuel glaze across the porceline they're pretty much done for. If its once a month that you're spraying it or something close to that then I would recommend checking them at every oil change. haha unless you don't ever change your oil
Nick
Old Sep 30, 2008 | 09:10 AM
dnkynrbk's Avatar
I Change mine everytime I go to the track. I had a nitrous backfire becuase I nip a plug. So now I change them eveytime I go to the track to spray. You may run a tr7 its alot better then the tr6s. Oh yea that backfire cost me a to have my motor rebuilt it busted the ringland.
Old Sep 30, 2008 | 07:11 PM
BOLO's Avatar
Thanks for the tip. And yes, I will switch over to TR7's---It was also recommended by Larry@ Speed Inc.
Old Sep 30, 2008 | 09:18 PM
LS1SpeedAddict's Avatar
where do you guys buy your tr7s from?
Old Sep 30, 2008 | 09:39 PM
BOLO's Avatar
Is the NGK BP7EFS known as TR7's? Can anyone verify this?
Old Oct 1, 2008 | 10:12 AM
Nick@HSW's Avatar
Well no. BP7EFS is broken down as follows:
B = 14mm thread diameter
P = Projected Insulator Type
7 = Heat Range
EF = Tapered Seat 17.5mm Reach
S = Standeard 2.5mmD center electrode
Two problems there for running EFI and big shots...non-resisted and projected tip. Take a look at this plug instead.
BR7EF
B = 14mm Thread D
R = Resistor Type
7 = Heat Range
I made a spark plug reference chart a while back and it used to be a sticky...I have no idea where it went now though.
Nick
Old Oct 1, 2008 | 10:56 AM
Great info Nick...so is the recommendation to run a 7 equivalent plug for a 150shot? Im still running TR55s with 6 degrees taken out...Im about to replace with a colder plug and was going to use the TR6s.
Old Oct 1, 2008 | 11:39 AM
Thanks for the PMs Nick!
Old Oct 1, 2008 | 09:41 PM
BOLO's Avatar
7 = Heat Range
BR7EF
B = 14mm Thread D
R = Resistor Type
7 = Heat Range
Nick
Thanks, Nick. Appreciate it.
Old Oct 2, 2008 | 09:26 AM
Nick@HSW's Avatar
Not a problem guys! Let us know how everything works out.
Nick
Old Oct 2, 2008 | 10:26 AM
LS1 SPEED's Avatar
BR7EF
B = 14mm Thread D
R = Resistor Type
7 = Heat Range
as posted by Nick is what we have found to work best
Old Oct 2, 2008 | 10:45 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Nick
Nick,
Its in this sticky
https://ls1tech.com/forums/nitrous-oxide/846230-everything-nitrous-related-stock-bottom-end-all.html
I use that information alot, thanks for posting it up way back when.
Old Oct 2, 2008 | 10:47 AM
JL ws-6's Avatar
Race your car!
For a 150 shot I'd run a #7 and feel that's pretty safe for what you're doing.
I have a #9 with the same amount of nitrous but an assload more compression so it needs a colder plug. I probably could get away with a #8, but the #9's have worked out good, being that i've been spraying the thing for a year and haven't had an issue.
I do change them every trip to the track too, I use the old plugs to load/unload the car on and off the trailer, then once it's unloaded I'll use them to go thru tech and whatnot, then I'll put a fresh set in for the first pass. This way the engine's already warm too, so the chance of fouling one out right away is alot less.
Old Oct 2, 2008 | 12:46 PM
Nick@HSW's Avatar
Originally Posted by Ray@Nitrous Outlet
Nick,
Its in this sticky
https://ls1tech.com/forums/showthread.php?t=846230
No problem. I always used to search under my screen name for it and its no longer listed in there. Glad to see it survived. Thanks!
Nick
