Rockford Fosgate P700-1bd
Up for sale is a barely used Rockford Fosgate 700 watt amp. i sold my old winter car and took this out. i plan on doing a cam swap this winter so im selling this to get parts for that. im looking to get $200 shipped and paypaled OBO. there is nothing wrong with this amp and is well worth the $275 new. i am also always interested in trades for parts just let me know what you have, just dont offer me junk
if pictures are needed text me at 574-309-4408, also for faster response text me or pm me.
Specs:
mono subwoofer amplifier
225 watts RMS x 1 at 4 ohms (450 watts RMS x 1 at 2 ohms)
700 watts RMS x 1 at 1 ohm
CEA-2006 compliant
Dynamic Thermal Management cooling system
variable low-pass filter filter (35-250 Hz, 12 dB/octave)
selectable subsonic filter (28Hz, 12 dB/octave)
variable bass boost (0-18 dB at 45 Hz)
optional wired remote bass boost
Class-BD amplifier design
MOSFET power and output stages
preamp-level inputs
preamp outputs
4-gauge power and ground leads and an 100-amp fuse recommended -- wiring and hardware not included with amplifier
no onboard fuses -- when installing multiple amps in a system, an additional 100-amp in-line fuse between the distribution block and the amplifier is recommended
10-1/8"W x 2-1/4"H x 8-7/16"D
Specs:
CEA-2006 compliant
preamp-level inputs
preamp outputs
