Ford 9" - 'Quick Performance' Housing
Here's a guy that just got through installing his QP 9". He even mentions that you can in fact adjust the pinion angle with the heim joints.
https://ls1tech.com/forums/gears-axl...e-install.html
Everything I've read about this rearend is nothing but good comments. I'm very anxious to get it installed and under the car.
Mike
-Strange 'S' Case Powdercoated Silver Metalic
-Detroit Locker 31 Spline w/3.25" bearings
-3.89 Visteon Gears
-QP Daytona Pinion Support
-1350 Billet Yoke
I saved the best for last. Check out the inside AND outside welds around the LCA mount.
Also, notice the bead weld down the length of the shock mount. I had to double take on it because it looked like one continuous piece of metal. No backcutting or gouges in the weld, no spatter, just a perfect bead all the way along that 90 degree edge.
Mike
I'm waiting on a torque wrench that measure inch/pounds (with a dial indicator), and then I can finish setting up the gears in the center section.
Finally feel like I'm making some decent progress.
Mike
Mike
Picked up the car from Cody's yesterday..sounds mean as hell although I could do without the sounds of them dang roller rockers! Those things are loud man! Yes, very very anxious to get the black car back on the road again. It's been waaaaay to long on jackstands lol...
I'm uploading pics of my freshly powdercoated QP housing in a few minutes. Just waiting for them to upload to photobucket now.
Mike
Spohn LCA relocation brackets I welded up this past saturday.
Modified stock sway bar mount.
LT1 Backing Plates
That's about it for now. Just need to finish the gear setup and clean up the underside of the car. I also need to bend up some brake lines and fab up a mount for the brake line Tee.
Mike
I'll call ya sometime this week about the bearings, now that I have the backing plates back from pc. Do you have a drill press? I need to clearance the backing plates so that I can remove the 3" long studs without pulling the axles.
Mike
