Northwest Members WA, OR, ID, MT, WY, SD, ND
Ford 9" - 'Quick Performance' Housing
Old Feb 9, 2009 | 06:09 PM
Mikey 97Z M6's Avatar
Default Ford 9" - 'Quick Performance' Housing
Anyone know anything about these housings? I know they're not a sponsor on here, but I'd like to get some opinions about this housing. It's got a different torque arm mount from the other 9" housings I've seen. Looks like you wouldn't need an adjustable torque arm since the mounts at the housing have Heim joints. Any thoughts?
FWIW, these guys make 9" housings for alot of different chassis'. They've been producing this one for the fbody for about 1-1/2 year or so.
Here's some pics:
Torque Arm Mounted To Housing
Torque Arm Mount
Old Feb 9, 2009 | 06:14 PM
NWDragRacer's Avatar
The heim joints can't really be used to adjust it very much. As they change length, the distance between them changes because they are in different lines. The mount holes are a fixed distance apart. Maybe a degree or two is all you will get.
I learned this with ladder bars and trying to adjust them.
Old Feb 9, 2009 | 06:24 PM
Ryan K's Avatar
Pathological Modifier
Actually you can get enough adjustment as long as you are adjusting the lower, not the upper joint... Another aspect is that they are farther apart than most ladder bar adjustors.
I don't think anybody in our area is running one, so as far as personal experience, knowbody knows. I do have one of their Spools in my car though.
Old Feb 9, 2009 | 07:52 PM
PONYEATER's Avatar
Great company to deal with, I have had alot of dealings with them for various drivetrain items.
Old Feb 9, 2009 | 09:12 PM
I've been dealing with Brydon over there at QP. I just ordered up some 9" parts from them. I didn't even know they produced this housing until I asked if they ever thought about producing one. It looks to be a solid, well thought out design and it's about 200.00 cheaper than a Moser housing/axle package.
Mike
Old Feb 25, 2009 | 09:44 AM
Well, after many email conversations with Brydon I finally pulled the trigger on this bad boy. Should be fabbed up by the end of this week, or early next week. Hopefully it will be here by Mar 10th or so. Once it gets here, it'll be off to the powdercoater to get the same Silvervein treatment as my BMR Kmember.
Ya, I'm excited!!
Mike
Old Feb 25, 2009 | 10:13 AM
I just bought my spool from them. Good service.
Old Feb 25, 2009 | 11:28 PM
Yes, great service and excellent pricing. They have some of the best prices around for rearend parts.
Mike
Old Feb 26, 2009 | 12:34 AM
CW00BlackTA's Avatar
Wondering if that upper TA mount would clear.
Old Feb 26, 2009 | 06:03 AM
WAHUSKER's Avatar
Looks nice Mike! Post pics when it's done.....
And ALL 9"ers need clearancing, hard to say about this one, might be better or worse than others.
Old Feb 26, 2009 | 09:27 AM
I know what you guys are saying about the clearance issues. Trust me, after experiencing the troubles Bobby went through with his Moser, and all the threads about having to "clearance" for the TA bracket, I did the research. It seems from everyone that posted in the "gears" section that owns one of these, it fits prefect with no "clearancing" needed. I believe it places the TA bracket a little closer to the driveline, so it's more centered in the tunnel. Same with the mounting point on the top of the housing, it's more centered in the tunnel, so there is more room up top in the tunnel. Another bonus is that everyone has said the stock length driveshaft is a perfect fit.
We'll see how it goes once it's here and installed. My car is pretty low, so this will be the ultimate test for clearance issues lol....
Mike
Old Feb 26, 2009 | 01:09 PM
99LSS1's Avatar
Hey Mike, Could you PM me the pricing info on this... I will be needing a new rear very soon. Trying to get it done without spending a fortune. Thanks, Doug
Old Feb 26, 2009 | 02:31 PM
Just sent you the pricing for everything I have into mine, including the used gears and used detroit locker. Less than $1750.00 for the entire rearend. Hard to beat that man.
Mike
Old Feb 26, 2009 | 09:44 PM
Mike
Yep. I have the Moser 9 inch and my ride height is pretty close to yours. That's why I was wondering! Looks like a good piece. Post some pics up when you get done.
Old Feb 27, 2009 | 11:08 AM
Elliott's94Z's Avatar
Remember that SS hood you wanted?? Trade you straight across for the new rear...
Old Feb 27, 2009 | 12:55 PM
WAHUSKER's Avatar
Installed of course.....Hell of a deal Mike, better jump on it!
Old Feb 27, 2009 | 02:11 PM
I know huh! Tempting. Very tempting............ lol...
Mike
Old Feb 27, 2009 | 08:42 PM
WAHUSKER's Avatar
You might be right about not having to clearance it Mike. I beat on my car before installing the M9 (lessons learned from the old Moser 9") and I don't think I needed to. That TA mount looks similar so maybe not. I'd check fit it first....
Old Feb 28, 2009 | 11:54 PM
I'm hoping for the best with the clearance issues. When Bobby switched to the Mid West Fab 9", he said it was much better than the Moser. We'll see in a couple weeks.
Mike
Old Mar 3, 2009 | 09:45 AM
I just found out my housing/axles and some other parts are shipping out today. Hopefully everything will be here by Friday so I can get the housing prepped for powdercoat. Wooooot!!
Mike
