Northwest Members WA, OR, ID, MT, WY, SD, ND
Nos
Old Oct 11, 2010 | 04:52 PM
chapmansZ28's Avatar
Default Nos
so how hard is it to install a NOS kits on a 98 ls1... ive heard its not hard just time consuming...
Old Oct 11, 2010 | 06:05 PM
freefallen.1's Avatar
ZPut the bottle where your spare tire is. There is a rubber plug that you can cut open to run the braided line all the way into the engine. Then put the nozzle in front of the maf and your done. Hardest part is not using it and zip tie the line
Old Oct 11, 2010 | 06:31 PM
sidewayz28's Avatar
you going to run a dry or wet kit? do you have an upgraded fuel pump and/or injectors? theres more to it then just installing a kit and spraying..
Old Oct 11, 2010 | 07:21 PM
No and no with the fuel system stuff... Ive been talkin to ellis a lil bit so ill prolly just have him put it on and do what he needs to lol and get the better tranny on it
Old Oct 11, 2010 | 10:43 PM
98goldz28's Avatar
If you say NOS in the n2o section you might get flamed. For some reason they don't like it. Happen to me so just trying to help a brother out...
Old Oct 11, 2010 | 11:46 PM
lol well thanks for looking out! and Its a wet shot sidewayz
Old Oct 12, 2010 | 01:06 AM
sidewayz28's Avatar
I think hes probably going to set you up with the same kit i have.
Nitrous Outlet 90mm plate kit.
Old Oct 12, 2010 | 01:02 PM
hmm very well sounds great to me lol
Old Oct 12, 2010 | 01:16 PM
JM0523's Avatar
I just bought the HSW wet kit and im going to install it this week and be spraying on the stock injectors and fuel pump, probably just a 100 shot, i paid 375.00 for the whole kit minus window switch
Old Oct 13, 2010 | 12:21 AM
stangtrader's Avatar
its simple and not too time consuming.just be for warned its like crack.
but all in all not bad to install.would upgrade fuel pump for added saftey,even though im still running a 125rwhp dry shot with br7ef plugs and every thing is going good on stock tune but deff check your plugs, so far i have run 30 ten pound bottles with good sucess
Old Oct 13, 2010 | 08:48 PM
oh and on this note... the nitrous kit is nitrous express. lol... so what fuel pump should i run? size and brand? and then also injectors... what size on those bad boys... ive been told many different things about injector size
Old Oct 14, 2010 | 08:48 PM
id go with a walbro 255lph pump as for injectors you should not not need them unless its a dry kit.wet kits make up for the needed fule buy the sielonoid. dry you need to spray before the maf and the computer adjusts fuel curves acordingly but there is a limit and you would be better off with a tune and injectors dependent on the size shot you run
Old Oct 15, 2010 | 02:37 AM
Well ima run a 150 wet shot... Will i b fine with just a pump? Or do injectors and get a tone? But im not getting a tune until i get mt tranny in
Old Oct 15, 2010 | 08:35 PM
fuel pump yes, you should get a tune for all out saftey but it will have to be up to your best judgment.i would deff buy some NGK br7ef plugs and gap them at .035.it made a world of differance on my car. idk every one says you need this and that to do any thing,i think most of it is for saftey reasons. but like i said im spraying a 125rwhp dry shot on stock fueling and tune and i have done 150rwhp wet on my car i just preffer a dry kit cause its more of a kick in the pants.my heads are currently off my motor for no reason realy and every thing looks great i was expecting to find chiped pistons or any signs of abuse but it all looks good and i have 130k on my motor.all i can say is use your best judgment and listen to your motor,read your plugs and put the for mentioned plugs in otherwise you will chase stupid gremlins like i did.
Old Oct 21, 2010 | 12:33 AM
well i put the ngk br7ef plugs on my car when i did my head swap. which was maybe 300 miles ago lol.... sorry i havent gotten back to ya... im down in cali with the military working like an animal.... and ill get the new fuel pump when i put it all together... i think i might just wait and do NOS, tranny from speed secrets, fuel pump, then tune and maybe dyno... 3500 for all that... and then maybe paint.... not sure yet might see what ellis thinks
Old Oct 21, 2010 | 11:49 AM
JM0523's Avatar
If your running any more than 100 shot id definantly at least pull about 7 degrees of timing even on a 100 shot you should pull 4 degrees, im running the BR6EF plugs
