This Is Interesting
And Steve, he's running Cartek stuff. That's why I mentioned Cartek earlier.
Anyway, been pretty much covered here but, basically four things will dictate:
Rear gears
Tire height
Max RPM of engine
Trap speed
There are online calculators that can get pretty close, but they don't account for tire growth, trans slippage for auto's etc.. A 28" slick will grow to about 29" at the big end depending how fast the car is.
It gets even more complicated choosing a rear gear when you want to run nitrous part of the time because then you have to compromise....
Mike
Rear gears
Tire height
Max RPM of engine
Trap speed
Mike
I notice also that his motor is not wasting much power on smoke and drama like most H/C/I setups.
Yeah there's obviously plenty of muscle there, but the powerband seems ideal for the specific combination of factors you listed above (gear ratio,tire size,weight,etc.)
Driver's fantastic reaction time doesn't hurt either.
I'm still pretty stoked about my Thunder Racing Raptor Cam but this Cartek heads and cam package sure looks good.
This video pushes the bar even higher, really showing the POTENTIAL of an optimized stock bottom end 346 "Sorry Mike but you should be shooting even HIGHER still with your big cubed monster.)
"big cubed" lol.... Don't forget I also get the 80lb weight penalty because of the iron block.
Mike
I seriously considered having AC Nutter Sleeve my LS6 so I could run the L92 heads and gain a few cubes myself.
His pricing was reasonable enough that it almost made sense.
Your are right though, 370 wouldnt be considered big Cubes except to someone with a 346
The 370 has only 24 cubes more than the 346 which should be worth apprx. 1.25 h.p. per additional cubic inch = 30 h.p. (apprx.)
In terms of a H/C 346 car, 450 rwhp is considered strong -but 480 rwhp is pushing elite territory!
I'd certainly rather have the greater cubic inches, A person could easily spend two thousand bucks on a set of heads that may only net a 30 h.p. gain when it's all said and done.
I think Mike has a Fantastic setup with a couple more cubes and comparable flow to even the Cartek cathedral port heads, his car has a little more potential than us 346 cathedral port guy's.
TFS 215's are not seeming so expensive anymore.
They definately know how to put a package together.
Realisticaly though, they are more than I can afford.
I think this car really shows what can be done with a stock bottom-end 346 with sufficient engineering,time,and money.
For me though, I have to look closely at the cubic dollars in order to play at all!
I can't even think about Cartek, That would take all my transmission money and Mike wouldnt like that!
Mike
Mike
Mike
Mike
