Northwest Members WA, OR, ID, MT, WY, SD, ND
Lt's on a lt1
Old 03-29-2011 | 03:24 PM
czechnuts's Avatar
All my mods are as follows. OK E3 plugs, MSD wires, under drive pullys, air foil, TB by pass, 160 thermo, K & N, stage 1 shift kit and a manual fan switch. Other than suspention upgrades. I bought these headers and a a flowmaster for a stock replacement. I'm lookin at a 52mm TB next. Do to what i can afford as I go along. Just not sure how much more I can do til I need a tune. Any idea of what HP I could be at with all this thus far? No worries if know one knows. Just curious. What could i do next thats affordable? Thanks
czechnuts's Avatar
Is Wong still on St. johns?
Old 03-29-2011 | 03:42 PM
*02WS6TURK*'s Avatar
9305 NE Highway 99 Vancouver, WA 98665-8979 - (360) 695-9433
I will be up there tomorrow,, stop on by.
Old 03-29-2011 | 03:55 PM
czechnuts's Avatar
I havnt put the headers on yet. I still need a Y pipe and fab work. Plus no cash till next week or so. Whats it by? Walmart?
Old 03-29-2011 | 04:13 PM
SalvageZ28's Avatar
Originally Posted by 02sslayer
How the **** did the op's lt thread turn into a 2012/religious thread? I dont think he is ordering from heaven performance
LOL hey you should pray a lil maybe your car might run better=) LOL and another thing with god on your side your always going to be a winner
Old 03-29-2011 | 04:17 PM
Old 03-29-2011 | 04:20 PM
It's in the same parking lot as Gaynors Automotive. Right across the street from Jack In The Box....or is that Carls Junior...
tmoney223's Avatar
Hey ditch the y-pipe and go X-pipe.. fTW!!
Old 03-29-2011 | 10:10 PM
Rockin C Racing's Avatar
Across from Carl Jr's that is next to Walmart.
I would try and do as much as you can before getting the tune, that way you don't have to redo it later when you add an item. You can run the long tubes without a tune. You will most likely need the tune to pass emissions, so start planning and set some money aside for that before your time in 2012. Another little item I would suggest to add would be a set of 1.6 roller rockers. Even on a stock cam that will help increase lift on both exhaust and intake. An engine is basically an air pump. Air in vs air out and the result in between is horse power. Headers will help get the air out and a bigger throttle body will help with air in, but if you don't change something between those two points, you won't see much change in the horse power number.
Old 03-30-2011 | 12:37 PM
czechnuts's Avatar
Holy religious battle! Next your gonna tell us Santas real!! Anyway. Carls sounds more correct do to jack is on 78th. You have an idea of the price range for tunes? I'm gettin close to 200k on this engine so I want to do a total rebuild. So at that time I plan to upgrade cam, rockers, manifold, and hopfully heads. But talk is cheap. Parts are not!! lol lastly. Do these engine blocks have the clearance to stroke or would I need the machine work like the 1st gen's? Thanks again. I've posted on the LT1 page and just got mumbo jumbo blah blah who's smarter. This is one of the few times people have spoke english. Plus haven't tried to 1 up each other.
Old 03-30-2011 | 12:40 PM
czechnuts's Avatar
Oh and but 1st things 1st. My car needs brakes and tires in a BAD way so next is headers and tb. Than after I begin what to do next....other than track!!
Old 03-30-2011 | 01:34 PM
  #32
I have a 383 LT1. I took mine to the machine shop and had them check for clearances. There is a little machine work needed for a 383 stroker, a 396 needs more clearancing. I believe Wong's tunes are around $500, but I would contact him to check. Also you will need to talk to him about tuning software.
