Northwest Members WA, OR, ID, MT, WY, SD, ND
Pacesetters and kooks..
Old Feb 3, 2012 | 10:00 AM
*02WS6TURK*'s Avatar
Originally Posted by SalvageZ28
1 7/8 is over kill on ls1 or ls2's motors.
No they aren't. Your not going to lose out on power or torque, only gain in these areas. This myth that they are overkill has been proven wrong by several builders on here such as TSP, Pat G and others. The gains even on a stock LS1 motor are better than 1 3/4. It's not a ton of power, but power is power.
Old Feb 3, 2012 | 12:19 PM
SalvageZ28's Avatar
Get the 1 7/8 and put them on your car and i bet you dont gain more then 5 whp. I see N/A cars doing over 500 wheel with 1 3/4. the only way i would do 1 7/8 is if i had a 408 or bigger.
Old Feb 3, 2012 | 01:03 PM
In BOLD. You just said it yourself, there will be gains by going with the larger headers. So if you are looking to get the best gains and get squeeze out every last HP, then they are the way to go.
Old Feb 3, 2012 | 05:29 PM
6goat0's Avatar
so my car woldnt run all mest up with boltons and no tune...
i dont know if it matters but i have the ls2 gto..
Old Feb 3, 2012 | 06:51 PM
No Hope's Avatar
It would run fine, maybe a little rich and you might get a check engine light. But it wouldn't hurt anything. Its best to do your mods in groups with a budget in mind. Bolt on's then a tune, forced induction or cam and a tune. If your going to get more midieval than that you won't need anyone's advice at that stage, at least not mine.
Find the best high performance shop in your area that doesn't mind sharing the technical info with you and ask them about a mod your going to buy. You can write down all the BS you want from the internet but you would be better off asking a shop that has seen the good, bad and ugly of just about everything you can throw at them.
I like a shop that makes their money from doing the installation and not from selling the parts.
Old Feb 3, 2012 | 08:27 PM
SalvageZ28's Avatar
LOL my main point is its not worth the extra money for the few ponies you get
Old Feb 3, 2012 | 08:34 PM
MEGATRONSS's Avatar
Yeah don't buy the programmer man, I think it's also a waste of $275 or whatever. Dyno tune or nothing IMO, or maybe mail order tune..
Old Feb 3, 2012 | 08:44 PM
No Hope's Avatar
I think there are 2 correct answers for this.
1. If you already have a set of 1 3/4" headers is it worth it to buy a set of 1 7/8" headers for the small gains you will get per cost of a new set of headers. That answer would be NO.
2. If you don't have headers now and are about to buy a set. Is the extra cost of upgrading to 1 7/8" for the small gains you will get per the price difference between the two. That answer would be YES.
Keep in mind of how far you plan on going with mods. I bought a set of 1 7/8" headers because I was planing on porting the heads and installing a bigger cam some day. That has changed after I started learning more mostly from this site. Now I'm going to install a Procharger so I would be better off with 2" headers. Am I going to get a set of 2" headers, NO. I would be better off spending that money on Cam with more gains.
Old Feb 3, 2012 | 11:03 PM
6goat0's Avatar
ok thanx to all u guys dat help me with this thing..i guess ill b tryin out the pacesetters...
Old Feb 3, 2012 | 11:06 PM
JUSTINSWS6's Avatar
Kooks or arh get some nice headers.
Old Feb 6, 2012 | 10:38 PM
MEGATRONSS's Avatar
^lol dude no get the pacesetters..
Old Feb 7, 2012 | 12:24 PM
  #32
94Z28-MSTGKLR's Avatar
I've had pacesetters before... I run Kooks now. Everyone has their opinion and mine is that fit and finish along with longevity, quality and performance are rated over just simply a performance gain. Pacesetters will eventually peil and rust, then leak, and all while looking like **** under your hood. Thats my opinion and good luck with whatever decision you make.
Old Feb 7, 2012 | 03:14 PM
  #33
JUSTINSWS6's Avatar
Dont get setters unless you want to have the under hood look like crap and start to leak. Buy quality stuff so it will last and look good.
Old Feb 7, 2012 | 06:15 PM
  #34
Lol what? So are you saying Pacesetters look like crap and leak? If so, you don't have a clue what you are talking about. Never once had a single issue with mine nor have I heard any of the local guys having issues. Mine still look like they did when I took them out of the box 2 years ago.
Old Feb 8, 2012 | 04:37 AM
  #35
02sslayer's Avatar
Ive had pacesetters for over two years and mine still Look good
Old Feb 8, 2012 | 07:19 AM
  #36
JUSTINSWS6's Avatar
Arron one of my friends has a blue trans am has pace setters. He has had them for 3 yrs and are going to kooks because they dont look good and he doesnt like the quality of how they are built after he saw my kooks. He is switching to kooks exhaust like mine. At the heads it has a slight leak and where the pipe goes on on the passenger side is leaking and making aeexhaust leak. Its just the quality of kooms and how much better thwy look and the true duals you just cant beat the quality and the tone and sound of the match.
Old Feb 8, 2012 | 09:43 AM
  #37
wpe's Avatar
wpe
You can buy pacesetters either coated or uncoated, if they are NOT coated, they won't look good for long once the paint is burned off. But that statement goes for any mild steel header that isn't coated. If you get their coated header, they will look as good as any header. All the Kooks or ARH headers that are made of stainless steel look better because they never rust. You can also have the option of coating a stainless header but WTF for?? You are spending upwards of $300 to save a bit of heat in the engine bay. I have never seen any real temp reductions that were significant. Nick at ARH says don't bother to coat their SS headers because they will tend to hold more heat and transfer it back into the chamber. Which I can't see how thinking back to the days of my thermodynamics classes. In any case the pacesetter headers look fine when coated and perform nearly as well if not as well as the more expensive cousins.
As far as 1 3/4 vs 1 7/8 there is a trade off, the larger tubes may cause you to loose some low end torque but may gain on top depending on your combination. The smaller tubes will promote more low end torque but may loose on top depending on your combo. On a stock or near stock engine with say a cam only, that statment will definitely hold true when going to large tube headers.
Old Feb 8, 2012 | 10:00 AM
  #38
GreatV8's Avatar
There are only gains to be seen across the board with the larger tube headers. Even on stock motors.
https://ls1tech.com/forums/generatio...o-results.html
Old Feb 8, 2012 | 11:15 AM
  #39
2002BLKTA's Avatar
I had the pacesetters and kooks on my 06 GTO and I will never again buy pacesetter headers. Call Marylandspeed I picked up the kooks 1 7/8 and midpipes for $990shipped. They fit much better on the GTO and you wont ever have to worry about the headers if you ever decide to go stroker or more cubes. The kooks are worth the extra $$$ in my opinion.
Old Feb 8, 2012 | 04:33 PM
  #40
JUSTINSWS6's Avatar
Yes but coating comes off and looks bad. Buy quality first and only do it once
