Looking for a tuner....plus questions
In the next couple weeks I'm going to be installing a new rear end with 3.23 gears. I've got 2.73s right now, and have an A4. My rear right now has a bent axle, and needs to be switched out ASAP. The thing is, I've got headers I'm going to want to put on here my car soon, as well as an ORY. Problem is, I don't have the cash right now to buy the plugs, wires, poly MMs, and the actual ORY, plus the time to do it.
So my question is, is it going to make my car undriveable having the different gears without a tune? I know my shift points and speedo will be off, but I can live with the speedo with my gps. I don't know if theres a possibility to get everything tuned (headers, gears) without my headers on, or if that will hurt the car.
Second part, if I do just get the gears tuned first, is there anyone local that would do just a gear tune for cheap(or free ) to get me by before I get a real performance tune for the headers?
A tune is not needed for just gears. The tuner really only helps correct the speedo in that case. You will need the parts installed to do a tune for them. It is almost impossible to make a tune before the parts are installed as every car reacts differently to the parts installed. Also I wouldn't say a tune is "Required" for just headers and ORY.
+1 on waiting on the tune till you have the parts on.
talk to Ellis at Speed Secrets
http://ssefi.com/index.htm
Contact Speed Secrets
We are located in Snohomish, Washington, and are curently available for cusomizations to your vehicle. You may contact us by phone or email to set up an appointment.
Phone: (360) 217-8150
Fax: (360) 217-8149
Email: info@speedsecretsefi.com
Address: 1422 Ridge Ave,
Snohomish, WA 98290
Fax: (360) 217-8149
Snohomish, WA 98290
