Tidbit's 1956 - LS100 (53 F100)
#44
Also was able to bolt a few things on. If the Seahawks do horribly. I might put more things on today. ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Also not sure where I should install my turbo oil return line. Suggestions?
#45
Wherever seems the "cleanest". I've used the side "boss" on the driver side before, but some folks claim that the timing cover works well too. As long as it's a down-hill run, you should be good.
#46
http://rgvtruckperformance.net/rgvtr...r-Head-Guide**
#47
I though that you were wanting to use an ls3 head...ie; casting #823 or #5364 or #821 ?? Sorry, I'm a little confused....but know that none of the "ls3" heads will work on anything less than a 4.0" bore.
#48
#49
#51
See this is why I need you guys. I was a little concerned with running these ls3 small bore heads on my +10 stocker. Should i just roll with the 853 and figure a way to get a new intake?
Maybe a holly one.
Maybe a holly one.
#52
Kind of quiet here.
243/799 heads would be a good choice. Better than the 853. And not too spendy. Have a nice valve job done. I know a guy out Beaverton way.
Folks will say that better heads don't matter on a turbo car. I believe that's flawed thinking myself.
That is a cool looking manifold though....
Ron
Ron
#53
http://www.jegs.com/p/Chevrolet-Perf...10494/10002/-1
Would this work? I'm unsure as to what would be the best head for my stock stroke. I can list all the parts i currently have from cam specs thru. Lmk
#54
I think that a set of 317's might be better suited to your needs, as they have 72cc chambers and the same ports as the 243's. You could build them to suit for much less than the GMPP pieces. I'll take a look around the shop tonight...I think that I might have a set laying around, but I'm not sure.
#55
Sooo, looked in the shop....kind of a variety of things, but I indeed DO have a set of 317's that I'll let go. If you have a single bare casting #799/243, I'll trade ya for the pair of 317's if your interested. If not, then I'll let the pair go for $200.00. I also have 3 #823 castings, but am going to keep a pair of them for my next shop project....but I'll just give you the spare one, if it will somehow get you closer to your goal?? Anyway...that's pretty-much it. Let me know if you're interested.
#56
We got snowed in today. So I had a few hours to bolt on some easy items. A little worrying as I believe my turbo might not fit the way I want it too. V bands are coming in soon. Will know for sure shortly. In the meantime some pics
![](http://www.winterhawksskatingcenter.com/wp-content/gallery/ikaika/image_23.jpg)
#57
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
#58
So guys.. I know I've been MIA. Moved into a house.. projects after projects.. life
Truck project is in the same place it was 3+ years ago. I plan to revive it shortly. But not without some other projects first!
After years of frustration and accumulating car projects.. Can you take a guess at what this is??
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_1401.jpg)
#59
Yes thats right damnit! I'm doing it.. no more crawling around and working out of a garage..
BTW, I did this myself with little to no help. I recommend finding friends if you want to make your life easy!
Visqueeeeeeeen!
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_1455.jpg)
That's a wall..
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_1593.jpg)
More walls.. but they look so tall! Yes thats cause (secrets)
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_1677.jpg)
How do you start up a 16ft wall? Answer is in the back.
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_2108.jpg)
Think I measured incorrectly? That looks like an 8 ft wall
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_2109.jpg)
OK.. I'll admit it the walls are kinda getting tall.. I need some $1200 help!
Visqueeeeeeeen!
That's a wall..
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_2251.jpg)
#60
Yes.. that lift helped my short legs very much!
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_2268.jpg)
hmmm.. Why so jagged.. Lets fix that. I think this is getting heavier..
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_2270.jpg)
It's called cheating mom!
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_2271.jpg)
Yes.. Work smarter, not harder
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_2273.jpg)
6 5/8 X 27 X 25ft. Its heavy and I only have myself![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_2274.jpg)
wait wait.. I forgot to ask Mr Bobcat!
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_2278.jpg)
PHEW.. that looks like the makings of a 2nd floor..
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_2279.jpg)
![](http://winterhawksskatingcenter.com/wp-content/gallery/shop/IMG_2280.jpg)
