Throttle body help
Originally Posted by Steve Goodwin
Okay after 3 months I finally got my T.B. back from Jantzer. So I polish up some stainless steel bolts and get ready to bolt it up. I did not realize until I went to hook the coolant lines to the Throttle body that the inlet tubes are missing from the Throttle Body.
So what do I do![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
So what do I do
I could see on a show car where you would want to do the bypass mod, but I had no intention of doing it, and for whatever reason, the proper sized hose was HARDER THEN HELL to find here in L.A.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Oh well, live & learn...........BTW, a couple of the mods on another forum read the emails Janzter sent me and said that because of his 'tude/shitty way he dealt with me, they would never recommend him/his products again, instead focusing on the Shaner or other TB's..............just my worthless $.02
It was not my intent to attack you Bobby.....geez.
OK, moving on.....2 things to consider here Steve.
1 - the tube on the head is smaller than the fitting that you need to connect it to on the radiator. So you cant' just run a hose from the head to the radiator. You need this adapter kit. (5/16" to 1/4"?)
2 - you don't need to worry about the tubes (or lack there-of in your case) being open on the TB. They have no connection to the air path. Mine are just hanging out there.....which is why Scott removes them.
And most people that run ported TBs have done the coolant bypass mod. But the few like Rott that haven't are screwed when Scott removes the tubes.
And for those that don't know, you shouldn't just plug both ends of this tube when you do the bypass mod. That hose 'burps' the motor of air pockets that collect in the head's cooling jackets. You could develop a hot spot & crack a head.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Well I've got nothing to cap off, but I sure I can find something to plug them with. My concern was do I need to plug or cap them off.
BTW I've still got your MAF ends, I'll bring them back to you if you need them, if not I'll store them in my car, sure we will hook up at an outing soon.
But no unless you want it for looks you do not need a cap, if scott wanted it really trick he could fill those holes in....
Originally Posted by NataSS Inc
Want to sell mine back to me? ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
The red color is really very cool, I just want to match up with all the polished pieces on my car. Also the port job on the one I got from you is very good at least from my unknowledgable and unsmart eyes.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Tech Addict
Originally Posted by Rokko
Actually those are Todds MAF ends and I have yet to pay him for them. We'll hook up sooner or later and I'll get em back.
Todd, I haven't forgot. Next time I see ya I'll pay ya.
That's why I've got the Shaner S3... irony is although the coolant passages are still there on the TB I did the TB bypass with $3.00.... Home Depot has "TB Bypass Mod" always on sale
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Originally Posted by WS6freak
That's why I've got the Shaner S3... irony is although the coolant passages are still there on the TB I did the TB bypass with $3.00.... Home Depot has "TB Bypass Mod" always on sale ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Did answer my question about pluging the hole; no need it was a straight shot.
#32
What is the Home Depot mod? I took one of the hoses went to NAPA purchased one long piece, Bobby's idea sounded good. Got home discovered the hose are two different diameters
I'm such a dumb ***.
I think I said that above somewhere.....except the dumbass part
And I know Bobby. I know how you are....no problem here either bud!
#33
#34
OK, so what did you all end up doing to convert the hose from 5/16" to 3/16"? I am asking, because I tried to do the mod today armed with 15" of 5/16" heater hose, then figured out the hard way that the only fitting that is 5/16" is the one off the radiator. So what do I use to change the hose size? I went to Autozone, they told me to go to Lowes, they told me to go to Ace. What part do I need?
#35
I see your from Tampa, I grew up in Sarasota, my parents live in Holiday.
#37
Snootch,
Checked your site, nice car not many of us have fooled with audio but we do have several members of the military. Appreciate what you guys are doing.
#38
Tech Addict
get a fitting with a 1/8" pipe thread and a 1/4" hose barb on the other end and it works perfectly. just use a hose clamp on the pipe thread part for the radiator side and the other side should slide right in the hose from the small part of the TB.
viola! instant adapter.
![](http://www.spaandpoolsource.com/productimages/spp/H48-3-2.jpg)
