defrost problem????
Chris
360-632-3444
Ill be in marysville till sunday morning.
part of the problem is the seat/defroster is on a self resetting fuse. That is why you have to wait 5 minutes for the seat to work.
I took my car in under warranty to get it fixed. Now it doesn't shut off after a few minutes, but after about 5 minutes the light on the controls flashes. But by that time the window is usually defrosted already, so I just turn it off.
I think when I got the warranty work, the just replaced the whole HVAC control panel. I'm thinking for my current problem, they don't have a wire plugged in well or something, but haven't gotten around to looking.
Hope this helps.
Hope this helps.
it kinda helped but my warranty is long gone... i have hardly any cash to spare because of a new baby comin, so I kinda need a bit more help.
Basically, it had something to do with the rear defrost switch being broken... it'd turn on for a little while, then shut off way before it should, and wouldn't come on again.
Both times, they had to replace the whole HVAC control panel (all three *****, defrost button, and all the stuff inside) since from what they said, the defrost button is integrated.
Replacing the whole HVAC control panel sounds pretty costly though if you don't have a warranty...
The only cheap and useful way to fix, is by placing a normal 30 amp circuit breaker on the drivers door panel fuse block. If that doesnt work, then just replace the circuit breaker w/ a 30 amp fuse.
Pic courtesy of this thread: https://ls1tech.com/forums/showthrea...hlight=defrost
