engine build update
7**hp at 7650
6**TQ at 5500
Don't have a graph yet. I had to fight to get those numbers out of him. most of the time they do a dyno run they don't even record the numbers, and just let track times do the talkin. Juinor is not a big fan of dyno numbers, as he puts it "Numbers don't pay the bills, Timeslips Do"
Hopefully when the project is all done i will get to put it on a dyno myself and then have some numbers for you all, but for now that will have to do.
As good as any of us that use power adders will be getting. We can race if that will make you feel any better. You should have me covered by about 2 seconds....again!
How much HP do you get when you take an ls2 434 at 15-1 and spray 500 to it?
NONE! 2 out of 8 cylinder liners crack and hyd lock the motor
So needless to say the motor is getting a iron block done right now, with o-rings, drilled for 1/2 head studs, half filled, and so on. So i will have to take the weight hit but o well, so stand by for new numbers, in a few weeks.
It does make me feel better that when it let go it was making well over 1K hp
So i think i have found the limit of the alluminum block, from what the guys say the internals are in great shape except for the two piston in the busted holes, but as for the motor it self there was no detination and a/f looked to be 12.8-13.1 up until the time it let loose, think it was just a case of too much cylinder pressure
Impressive Sardog....sorry it let go, but impressive!!!
As for the 80lb iron block hit, what you're doing will make it worth while.
When do you get back in the states?
