Northwest Members WA, OR, ID, MT, WY, SD, ND
engine build update
Old Jan 4, 2006 | 06:49 PM
  #41
Nate_Taufer's Avatar
Originally Posted by sardog46
Ok got an update for you guys.
How much HP do you get when you take an ls2 434 at 15-1 and spray 500 to it?
What type of n2o setup were you running? Obviously direct port, but dual stage, progressive? Also seems lean for a shot that big. I don't know why they wouldn't start out with a small hit and work from there monitoring everything. But hopefully the iron block works out for you.
Nate
Old Jan 5, 2006 | 03:01 AM
  #42
sardog46's Avatar
Originally Posted by Nate_Taufer
What type of n2o setup were you running? Direct port or plate? dual stage, progressive? Also seems lean for a shot that big. I don't know why they wouldn't start out with a small hit and work from there monitoring everything. But hopefully the iron block works out for you.
Nate
Direct port single stage, can only run one stage in 10.5 car class. 15-1 is the compression ratio, a/f was around 12-1 It failed b/c of cylinder pressure, cracked two liners, they started right with a 400 cause thats the smallest shot it would take to hang with the big boys. any smaller than that and it would be useless. The ls1 is a great motor, just the alluminum block has it's limits and i reached them remember this is a race motor max effort!
Old Jan 5, 2006 | 03:29 AM
  #43
TwoFast4Lv's Avatar
Iron and rocked is the way to go I think I know some one with that combo
You **** is going to rock Dog I will probably only get as good as your N/A numbers
Old Jan 5, 2006 | 04:20 AM
  #44
sardog46's Avatar
Old Jan 5, 2006 | 11:52 AM
  #45
WAHUSKER's Avatar
You & me both.....including our power adders!
Old Jan 5, 2006 | 07:25 PM
  #46
Ah I see. True 10.5 is an extremely competitive class. I think you definitely reached the limits of sleeved block. Hell 15:1 is enough cylinder pressure as is. I am going to be doing a dual stage progressive setup this year. I am trying to spray around 400 onto an aluminum block. I'll only be around 11.5:1 but we'll see how it goes. I think the progressive nature will really help control the hit.
Nate
Old Jan 5, 2006 | 11:21 PM
  #47
sardog46's Avatar
Nate
what cubes you going to run nate?
Your right at 15-1 there is a alot of cylinder pressure. My first concern was lifting heads, but that wasn't even close to the problem. To make shure this doesn't happen again the new iron will be block filled about halfway. W to W just built a 1700 hp iron twin turbo, So it can be done, just have to wait and see.
By Brett Foote | 2026-06-04 05:00:17
