Local Engine Builders
Rick
Good luck.
(1) LT1 Block that has been splayed to 4-bolt main with Milidon Main Caps. It was heat sinked and checked. Block only needs decked and bored
(1) SCAT 9000 Series Crank Shaft, Part # 9-350-3750-6000-L still sealed in box. http://www.scatcrankshafts.com/
(1) Set of LE Custom Ported Heads, no flow numbers since they were never assembled.
(1) Set of Ferrara Valves for the LE heads. I want to say 2.02 and 1.60 on the valves but cant remember for the life of me.
(1) Set of [16] 1.6 Roller Rockers from Dyno-Flo. This is a Comp Cams Pro-Magnum RR knockoff. They are brand new in the box with only one set of retainer nuts opened for visual check. Part # RKSS-350B 1.6 www.dyno-flo.com
(1) Set of K-Motion Valve Springs, Part # K-800 http://store.summitracing.com/egnsea...%2C+400115+115
(1) Cloyes Timing Chain Set, Part # C-3092
(1) Set of [16] Comp Cams Titanium Retainers, Part # 731-16 http://www.powerandperformancenews.c...&Category_Code
(1) Set of Perfect Circle Performance Rings, Part # 315-0033.030.
(2) Sets of King Main Bearings, Part #(s) MB557SI STD and CR 807SI STD http://www.kingbearings.com/
(1) Set of [8] Eagle "SIR" I-Beam Connecting Rods, Part # SIR6000BBLW. http://www.eaglerod.com/products/Che...BC%20rods.html
(1) Set of [8] Probe Industries Pistons, Part # 12337-030. http://www.probeindustries.com/Pisto...D/Chev_383.htm
All of these products are brand new and never used. Some are opened for visual inspection only!
I was wondering if I knew who owned that car, but when I passed you I couldn't see your face...Then when you came zooming up, I knew I knew who it was
Very nice ride!
Also it's how comfortable you are with turning a wrench. I've built 2 motors on my own and both have zero problems. 1 in my turboed nova I had and a 4.3 in my boat. There is no real trick to build just an all around good motor. Just get that torque wrench out and follow directions...
Jason
Very nice ride!
