tire and wheel help
My options are variable but my budget it very limited to almost none existent now.
A. buy a set of 15" x10 wheels and run a MT Street 26X11.50-15LT tread width 9.8 sidewall 12.0
B. buy a used cheap 17x11 pair of what ever I can find cheap and run MT Street 26X11.50-17LT tread width 9.5
sidewall 11.1
C. Buy nothing at all and learn to launch with 30 series tires.
OR I'm open for suggestions. I was leaning towards the MT Streets from reputation, should I be looking at a different tire? Also what about the wheel? Should I look at a stock 16 inch rim instead and try and matgch a tire to it? I'd be cutting my width down a lot by doing it, will that defeat my purpose?
I need to drive to the track with the tire on the car or maybe not? I could haul them I guess. If I did that would a slick on a stock 16 in rim be my best bet?
Here's what my car looks like with 15" Centerline Convo Pro wheels, and 255/60/15 MT ET Street radials. Those tires equate to a 27x10.5x15:
https://ls1tech.com/forums/northwest-members/519292-yes-s-right-more-wheels.html
As for a 28 inch tire... it'd be really close. You'd have to measure... it wouldn't have fit in mine without some clearancing, rolling the fenders, etc. So I went with a 27" tire, because I didn't want to do any of that stuff.
So my best bet is a 15 in rim with 27 inches total. What about width? My well is already modified for the 18x315's I run on there now. But they are a +53 offset. Didnt have to roll the fender at all. Not even close.
Also, just because you fit a properly backspaced 18x315 in there, doesn't mean you'll be able to fit a 275x60x15 tire in there. It all depends on the backspacing...
We have 3 choices as F-body drivers. You can get Bogarts, which are properly backspaced for our cars. Only problem, you're looking at at least $2000 for wheels and tires.
2nd choice are Welds. Welds can also be had in the proper backspacing. These are a lot cheaper than Bogarts. Only problem, they won't clear our brake calipers. So you have to grind the hell out of the calipers to get the Welds to fit.
3rd, we have Centerline Convo Pros which is what I have. Cheaper drag wheel and clears our brakes just fine. Only problem, the backspacing is all wrong. So, the wheels will stick out of the fender well if you get too wide of wheels. I have a 15x7.5 on the rear... if I were to put a 15x8.5 wheel on, it'd stick out about a half or full inch past the wheel well. That's fugly, IMO. So, I'm limited in the width of tires I can have.
more phking money I dont have. Ok I have a friend with silver zr1's that I'm selling my chrome zr1's to. What if I buy a pair of stock zr1's or even a stock 16" z28 wheel for the fronts?Is there a tire I can run on those rims to match up with the QTP? How feasible/stupid is it?
that sounds kind of scary. Cant I get a cheap bias ply tire for the factory 16 inch rim and be smooth? But what about these rims here: http://www.diamondracingwheels.com/Pro-ChalSeries.htm
Will they clear the brakes? only $69 per wheel and 7" backspace at 20.5 pounds. Too heavy?
