Northwest Members WA, OR, ID, MT, WY, SD, ND
Engine Help Needed
Old Oct 5, 2006 | 04:59 PM
vtec this's Avatar
Default Engine Help Needed
I was coming home today and about 1/2 a block away from my house my engine started clicking very fast and loud. My idle also went up to 2k. I am going out to pull the valve covers off now and see if it is a spring issue or not. I have about 22k miles on my comp 918s so I am hoping that is the problem.
Any other suggestions?
Old Oct 5, 2006 | 05:15 PM
vtec this's Avatar
I found the problem. I am missing spark plug #8
It somehow musta just worked its way out and decided to bail on me. So I guess I will be going and getting a new one.
Old Oct 5, 2006 | 05:16 PM
Tranzor's Avatar
Did it throw any codes? Can't remember if you have all your codes disabled or not.
If the ticking is only on one side of the engine, and on the top side, I would say most likely a spring or maybe a bad rocker or something. Definitely pull the valve cover on that side and see what's going on...
Patriot Gold Dual Springs are pretty good.
Old Oct 5, 2006 | 05:17 PM
Tranzor's Avatar
lol Well, glad it was something so simple! Easy enough to fix...
Old Oct 5, 2006 | 05:20 PM
vtec this's Avatar
No kidding! I will probably just replace all my plugs then anyways.
I am very thankful that a plug is all that it was!
Old Oct 5, 2006 | 06:19 PM
99LSS1's Avatar
Glad to hear it was only a plug. Did you not tighten them all the way last time you changed them?
Old Oct 5, 2006 | 06:28 PM
LSxChevelle's Avatar
While you don't want to go too tight you should do more than finger tight...
Old Oct 5, 2006 | 07:12 PM
TwoFast4Lv's Avatar
HMMm...............
Do you REALLY want us to answer that one
Old Oct 5, 2006 | 11:11 PM
vtec this's Avatar
The last time I changed them was when I did my cam a couple of years ago.
I changed them all today so they should be good now.
Old Oct 6, 2006 | 07:41 AM
WAHUSKER's Avatar
That is a weird one Ryan! Glad it was something simple.....
Old Oct 6, 2006 | 02:30 PM
99LSS1's Avatar
Originally Posted by TwoFast4Lv
HMMm...............
