Turbo Tech dyno day results
#101
Originally Posted by TwoFast4Lv
Robert the reason I keep mentioning the MAF fail is when it does it reverts and goes WAY lean.......like imagine shooting juice and NO fuel
Ask Cory and Jim about it. they are well versed!
Talked to george today and ok'ed the forgeing of current motor. Can do it on the cheap, as he has a handle on some good forged prices. said everything looks good and can be reused. Will be about amonth and it will be back with a bigger hit. Also adding studs, head gaskets and some valve springs. First goal-looooow 10's. Oh, George said when I hit the juice, the slick wrinkled so bad the rim was almost spinning on roller, gotta love that torque
When's your car going to be ready?
Robert
#102
Just a follow up on the videos. Putfile has fixed their new page layout so you can once again download them directly from Putfile.com.
http://media.putfile.com/2007-Turbo-Tech-Dyno-Day
http://media.putfile.com/Roberts-Meltdown-2007
#103
Changing the MAF fail frequebncy is not enough. You need ALL your tables related to airflow tuned in manner consistent with a big FI car to ensure it doesn't happen again. You will also need to tune you open loop AF ratio table to something safe. Why? Because thats what your fueling goes to when any of the other tables gets exceeded. But it doesn't only go to the 14.x AFR that is there... it misses the mark and goes even leaner. I run my Open loop AFR table in the 11.x range for AFR at anything above idle. I recommend you do the same.
#104
Originally Posted by CHarris
We saw high 16.x to 1 AFR ratio virtually instantly. That was with nice fat 11.x to 1 ratios a split second before. The really cool part.... no codes thrown or retained. I had to make it happen about three times to see the check engine light flicker enough that I could see it. Again... no codes were tripped or retained in the scanner.
Robert
#106
Originally Posted by Robert56
Concenus is timing and plugs and maybe the fuel. Ellis is the only one that has suggested MAF fail. Dry hits are not tuned like FI cars, totally different animals. I have had absolutely no, none, nada, zilch, zero lean spike or lean issue and over 200 sprayed passes. Was watching WB and a/f was at high 10 area.
Robert
Robert
