Dropping fuel pressure.....need help!
This just started happening. Is that alright? I have the racetronix upgraded fuel pump. This never used to happen and I can't pinpoint what's causing it.
I'm worried that when I spray my nitrous it'll be more of an issue.
Any help or guidance would be greatly appreciated.
Thanx
I'm going to double check it on the way home and see if it wasn't a freak thing
In my last dyno pull the fuel psi goes from 62-57 psi but holds AFR just fine. Fuel filter? I dunno dude but I hope your fuel pump is easier to change than mine!
Any suggestions????
Robert
Robert
I'm not going to spray with that big of a fuel pressure drop under N/A conditions. Which means it may be a while till I hit 10's.
And I have 2 full 10lb bottles of juice in my house awaiting the chance to hit the elusive 10.XX.
Every time I let off the gas it goes way lean..........which I hear is normal.
I'm thinking I should put a bottle of juice in and run it down the freeway to see what happens to the A/F/.....
What do you guys think? Is that a bad idea?
Could it be a bad fuel pressure regulator?
that's what I would do,
I would trust a good wideband
that will tell you what your engine is actually seeing
Thanks.
Depending on how things go, I may make it out Saturday......we'll see.
Thanks.
I hope everything turns out ok, my suggestion..........stay N/A, lol, this way I can keep up w/ u.
Does this happen to anyone else? Should I be concerned? I'm thinking of heading to Bremerton tomorow and see if the car will be okay. I'm going to run down the fuel and put some race gas in to be safe, but I'm still worried!
