Ignition fuse popping...
I have a short somewhere and don't know where to look next. I switched from a T56 to Th400 recently. Finally got the car driving last night and got maybe 10 miles and the car shorted out mid drive but engine stayed on. So I limped it home and turned it off as something didn't feel right. Went to start it up and nothing happened. Lights turned on, but no crank.
Found out the 50A Ignition fuse in the number two fuse block is popped. The dome light turns on, as does the stereo, but the headlights, gauges, odometer and such won't turn on. Well they will with a new fuse but the second you go from the on to the start position it pops the fuse.
I traced the pink 12awg wire from the ignition back and it looks fine. Any suggestions or am I looking in the wrong place? Could the starter wiring cause any of this? I really don't know where to go next. Any suggestions?
Marty.
I have chased simular issues before. Start by carefully checking between the transmission and bellhouseing to make sure no wires got hung up on you. I have seen it a few times. Some times they are fine till every thing warms up and the cover fully melts.
Also check your T56 solenoid wires. I can not remember what fuse they are on but some are on that fuse also.
I think the worst one I had was one that came in for the transmission going into limp mode. After removing ,inspecting and reinstalling the harness I found the problem. MORE importantly while I had the harness apart I found about eight things spliced in on the circuit from the factory that were not covered in the books. In the end a bad B2S2 O2 sensor was at fault. We put in a new O2 sensor and the transmission started working fine again.
The moral of that was some thing totally un-related could be the root of your problems.
Good luck!
Good luck!
Marty
