Northwest Members WA, OR, ID, MT, WY, SD, ND
M9 Install
Old Apr 23, 2008 | 08:12 AM
WAHUSKER's Avatar
Yeah, I need to check the drive shaft, might be too long now. Always something....
Old Apr 23, 2008 | 11:15 AM
WAHUSKER's Avatar
After trying everything I can think if, I still have an interference with the ABS sensor. The 1st pic shows where the ABS sensor used to hit the gas tank at stock ride height vs where it hits now with the rear end at the lowering spring position. The last pic shows that it would fit without the ABS sensor installed.
I have -3* of pinion angle vs the tranny pan & drive shaft which I believe is the max you want to run. I tried moving the gas tank. I re-did the cross member hole. Thought about trying adj LCAs, but that would move the bottom forward, not the top. Out of ideas. Waiting for word from Moser....oh, and the DS fits Chad.
Attached Thumbnails M9 Install-m9-fit-issue-6.jpg   M9 Install-m9-fit-issue-7.jpg
Old Apr 23, 2008 | 11:18 AM
ablakez28's Avatar
Hope you get it figured out man. Wish I had a tip for you but....I don't. Parts look great though.
Old Apr 23, 2008 | 01:24 PM
Ryan K's Avatar
Pathological Modifier
Mark, Time to pull out the Dead blow (BFH mod the tank, it'll be fine...)
Ryan K.
Old Apr 23, 2008 | 02:39 PM
WAHUSKER's Avatar
Use a BFH on a plastic tank? I've thought about "forming" the tank somehow....but it's full of C16 race gas & heating it up doesn't excite me for some reason. And I would guess it would have to get pretty hot for any bending / denting to be permanent. Have you done it Ryan?
Old Apr 23, 2008 | 02:43 PM
Tylerb59's Avatar
Fire bad.
Old Apr 23, 2008 | 03:34 PM
Ryan K's Avatar
Disregard!
I didn't realize that was a plastic tank I was looking at. Poo! (You could pump it out and hit it with a heat gun)
Ryan K.
Old Apr 23, 2008 | 05:53 PM
PONYEATER's Avatar
step one: Take stock tank and fuel system out
Step two: sell current fuel system and stock tank
Step three: Buy fuel cell and bigger fuel system
Step four: Be happy you just bypassed 2008 mods into 2009 mods! Your ahead of the game.
PS:
You know you want a fuel cell all the other cool show cars are doing it.
Old Apr 23, 2008 | 10:43 PM
WAHUSKER's Avatar
Not an option Aaron. The M9 broke the bank, and I still gotta get the roll cage installed, get the tube front end aligned & replace the windshield....gotta make this work. Not to mention I don't need a bigger fuel system than the one I just bought (good to 1100rwhp).
Old Apr 23, 2008 | 11:22 PM
shannon french's Avatar
man this sucks. bettor to weld/heat witha full tank than an empty one. its under teh same reason why they weld natural gas lines with gas flowing through them but goo dluck sice all that fluid will dissapte heat fast as hell. maybe u in a new drian teh tank and dremel out what u need to and fiber glass in a "relief". could use a cut piece of pvc to mock it all up. dunno if that helps out at all
Old Apr 24, 2008 | 07:12 AM
Steve Goodwin's Avatar
I feel for you buddy and I do get that spend more money is not the answer for you looking for. I am betting that between Dan, Ellis, Ryan, Don and yourself somebody going to find a fix.
It is a hot looking rear end.
Old Apr 24, 2008 | 09:33 AM
  #32
crazylane's Avatar
Why dont you just take out the ABS sensor until you have the money or means to be able to fix it. Simple, cheap, and gets the job done. Who needs abs anyways???
I took mine out, along with traction control. Just put a peace of black tape over your dash light so it won't remind you..
Old Apr 24, 2008 | 09:52 AM
  #33
WAHUSKER's Avatar
At the moment the only way I can drive the car is with stock springs & no ABS sensor.....kind of defeats the reason I bought it ---> tucking my fat tires in the fenders with it lowered & having ABS for road races.
So far I've seen 4 write-ups where these were installed into F-bodies. The 2 guys with fuel cells had no problems & the 2 with stock tanks had problems.
Old Apr 24, 2008 | 09:56 AM
  #34
Ryan K's Avatar
Drain the tank and use a heat gun, its not going to get any where hot enough to have a fire problem.
Ryan
Old Apr 24, 2008 | 10:22 AM
  #35
WAHUSKER's Avatar
Ryan
That is what I was thinking Ryan. I have a heat gun, I just need to get something to make the right shape like a curved body shaping anvil (or whatever they are called). Maybe one of my dumbells would work....ha ha, a dumbell, that's good, maybe I should use my head.
Old Apr 24, 2008 | 11:12 AM
  #36
WAHUSKER's Avatar
I just got off the phone with Ron @ Moser Engineering. He wants a link to this thread so they can look at the pics & see what they think. He told me they are VERY motivated to fix this so other people don't have this problem. SWEET! Thanks for the call Ron!!!
Old Apr 24, 2008 | 04:46 PM
  #37
sardog46's Avatar
Hey mark i think forming that tank will be a bitch. might be easier to get a metal junk yard tank and form it. I think if i remember correctly that the stock tank is pretty thick plastic and you would have to get it pretty hot to get it to hold shape. But good luck to you withever you try to do. If it were me i would just build in a new fill plug and shitcan the abs but that is me Race cars don't need brakes.......just parachutes.
