Northwest Members WA, OR, ID, MT, WY, SD, ND
Need 1 stock piston...
Old Apr 22, 2008 | 03:05 PM
LSxChevelle's Avatar
Default Need 1 stock piston...
Well pulled Josh's motor and found the news... 3rd back on drives side had something go through the combustion chamber. Piston has a small hole from whatever went though.
So anybody have 1 good stock pistion laying around?
Old Apr 22, 2008 | 03:06 PM
Good news is that the cylinder looks like a quick hone will save it.
Old Apr 22, 2008 | 06:20 PM
Ryan'sSS's Avatar
I have one or two that look good.
Old Apr 22, 2008 | 07:09 PM
Where are you located?
Old Apr 22, 2008 | 07:30 PM
Ackattack1's Avatar
I have one
Old Apr 22, 2008 | 07:32 PM
Ryan'sSS's Avatar
Bremerton.
Old Apr 22, 2008 | 08:24 PM
TwoFast4Lv's Avatar
Un-less the ring land is messed up why change the piston? You are already rolling the dice on a cheap fix so why not just clean up the nicks and put it back in and not wory about the ring pack?
Besides I would be more worried about the rod and or bearing failing in the future then the piston.
Old Apr 22, 2008 | 09:03 PM
HitmanLSX's Avatar
What do you do about the hole though?
Old Apr 23, 2008 | 12:24 AM
Not rolling the dice, this is why I can't just clean it up... Already doing new bearings although they did look just fine. Also will be doing all new rings.
Old Apr 23, 2008 | 10:07 AM
crazylane's Avatar
Dude, that hole it just for better oil sepage... Theres nothing wrong with that there piston...
Old Apr 23, 2008 | 10:23 AM
TwoFast4Lv's Avatar
LOL Seeing the side of the piston make more sence
Old Apr 23, 2008 | 10:59 AM
B-RAD2's Avatar
Damn that sucks.. almost as good as mine jason...
http://rides.webshots.com/photo/2335...56155130RZJaxa
Old Apr 23, 2008 | 11:04 AM
HitmanLSX's Avatar
Glad it didn't damage the cylinder wall too bad looking like that
Old Apr 23, 2008 | 12:21 PM
Poik's Avatar
How bad is the head?
Old Apr 23, 2008 | 01:11 PM
TwoFast4Lv's Avatar
The big Question is WTF went in the cylinder?
I still think a little JB Weld and it will be fine
Old Apr 23, 2008 | 01:24 PM
Tylerb59's Avatar
VTACK! kicked in a little bit too hard.
Jason, you and your Dad should give yourself a big pat on the back for helping Josh with his situation, it's been a long time coming.
Major kudos to you, sir.
Old Apr 23, 2008 | 02:15 PM
HitmanLSX's Avatar
No **** LOL!
Old Apr 23, 2008 | 04:39 PM
Tails's Avatar
I was thrown by the term, "small hole"
Old Apr 24, 2008 | 04:56 AM
KrautBurner's Avatar
those are mine
Old Apr 24, 2008 | 05:21 AM
HitmanLSX's Avatar
Are they ls1 or ls2 pistons?
