Opinions on this aftermarket hood...
what company made the hood ? ... warning stay away from liberty fiberglass . those
hoods are total **** . they also go by HOOD FOR SALE ON EBAY. i had a bad experience
dealing with them . they got a F rating with the ohio BBB.
It's hard to tell because of the black, but it looks like you had fewer fitment problems than I did with my VFN hood that cost 3x as much.
I would cut out the scoops and hood brace, order a couple of factory screens for the nostrils, have it painted body color and call it good.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
You could show up without your hood so you can test fit. It will probably take some time to get it to fit perfectly, you may need to adjust your fenders & head light covers, a couple of times before everything lines up good. Dont expect to be able to just bolt it on and go, there is a little more to it than that. Also if you just bolt it on don't expect everything to be perfect, you will also need to get the latch situated before you head home with the new hood. I have heard rumors that a hood will fit in the hatch, but I have never tried it.
If it takes that much work then in my opinion it is NOT a good hood. My suncoast hood literally bolted right up and fit great. It was a little low on the passenger side front but I just raised the hood bump stops so it wouldn't sit as low and now it sits perfect. The latch bolted right in and required no adjustment whatsoever. In my opinion THAT is a good hood.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I feel like I was VERY lucky. I agree as I've looked at aftermarket hoods over the years how inconsistant they can be! All I'm saying is if you can get it to fit with out having to mess with the fenders the go for it. If it's going to require moving fenders then it's not worth it bc then the rest of the car panels might become un-aligned. If that is even a word.
Ok in the front, it "teeters" on the latch. To get the left corner down, raise the rubber stopper on the right. If it requires SO much of that that the right is too high. Lower the bumpers and lower the hood latch assembly and start again. For the back, you may need to bore out the existing holes in the hinges to get the amount of adjustment you need. Washers will raise the corner that needs it. Don't use the factory hood struts as they will put too much stress on the hood and crack it eventually. Vfnfiberglass.com sells 'lighter' hood struts for like $40 and will give you a LS1Tech.com member discount.
