got CME valance painted.. but doesnt look quite right
The only way to get the paint to look perfect is to blend it!
well your car is 8 years old... the paint on your car is probably going to be faded a little, if you gave the guy a paint code then its going to be brand new paint not blended
exactly right. only thing i could say is if hes a really good painter see if he can blend it up into the bumper but your still working with new and old white paint
some painters are high on fumes i had a painter do some pretty stupid things so i just do it myself now. but ya its probably just that your car is faded. Or its because white is hard to match along with red.
also when you gave him the paint code did you leave anything for him to try and match the color to aswell? if you left a paint code only most guys just take the standard varient and go that route. whites the most noticeble when it comes to paint ware. fresh white will always look better then whats around it especially on paint that has been aged.
i might go tomorrow morning to see what he says
i went to muffler doctor, i think that's the name, in montclair... there pretty good PM if you want more info about them
well i left my car there pretty much lol, he painted it and installed it... than came back and it was on my car and evreything... well he told me to go back if i wasnt happy about it, i might go talk to him just to see what he says cause even he told me it didnt match and he can maybe do lighten it up ( the white is darker on the valance)
#33
Your painter probably didn't match it to the specific variance of your actual factory paint. Just because it says "such and such" for a paint code doesn't mean that you just throw that code in the gun and spray away. He should have sprayed out some test cards with different variances to more closely match your actual paint color. Some colors have 5 or 6 different variances, I found that out the hard way with both black and red.
#34
Looks close enough to me, and I own a bodyshop.
If you were given the option to blend, and you declined, its your fault. I can't believe he will re-do it. I also cant believe you want it re-done.
Different plastics change the color of the paint. Metal and plastic does not come out the same, even when painted at the same time with the same paint.
Its not noticable, and chances are, if he re does it, you probably still wont be happy. If it isn't noticable until it gets pointed out, then you should be happy, being that you declined to blend the bumper.
#37
I have always had great luck painting individual panels on vehicles by getting the painter to spray out some test cards with different variances of your particular paint code. I have always got the new paint to match almost 100% without blending just by picking the matching test card to the original paint under sunlight. I have always heard blending should be the last resort. Blending seems to be the lazy way to matching if you ask me. Now, if your vehicle's paint is in poor shape to begin with then you might have more problems with the match either way.
And by the way, black can be a bitch to match too.
#38
Paint shops are not using the same paint as the manufacturer, so it NEVER looks exactly the same. Small things make a difference, size of metallics, transparency of pearls, etc.
Butt matching is not the right way to do it, no matter how long you spend on tinting the color.
