Door Hinges or Pins?
Old Feb 17, 2009 | 09:33 PM
hempkat94z's Avatar
Default Door Hinges or Pins?
I am in desperate need of some door hinges or just the door pins. It is flat sided and the damn door is loud as **** every time i open it. Who sells them???? I can't find a dealer anywhere. Thanks
Old Feb 18, 2009 | 05:54 PM
cvalliere's Avatar
You can't find a chevy dealer anywhere??
Old Feb 19, 2009 | 07:44 PM
VTJosh's Avatar
Not sure but my driver's side door has a similar problem, that when I open it, it drops about a quarter inch and it makes it a pain to close. I have to slam it pretty good. I was told it was the hinge pin but I haven't had a chance to hit up the dealership. I know Autozone doesn't carry them.
Old Feb 20, 2009 | 11:24 AM
hempkat94z's Avatar
From what my local chevy dealer said is "They CANT get them". How do you argue with that. If you can get it from you dealer get me the part number. Thanks
Old Feb 20, 2009 | 05:18 PM
cvalliere's Avatar
You can't get what hinge pins? Because i don't think the hinge pins are actually serviceable.
Old Feb 20, 2009 | 11:05 PM
hempkat94z's Avatar
I will post a pic tomorrow.
Old Feb 21, 2009 | 01:44 PM
cvalliere's Avatar
What exactally is it the dealership says they can't get?
*EDIT* I called the parts department at work (a GM dealer), GM does NOT offer a hinge pin kit. You have to replace the hinges. Here are the part numbers as follows (drivers side only)....
- Upper hinge: part# 11630875 - $31.68
- The system says that a "plate kit" is necc. to install the hinges (I'm assuming it's a plate for the bolts)...... Part #10268961 - $9.23.
- Lower hinge: 16631043 - $92.95
- Spring: 20300149 - $9.04
Old Feb 22, 2009 | 09:21 PM
Snipezzz's Avatar
you can buy them direct!!!
Old Feb 23, 2009 | 06:39 PM
cvalliere's Avatar
^^^ Buy what direct? And from where?
Old Feb 23, 2009 | 07:10 PM
evilZO6's Avatar
why even bother? Do you know how simple it is to take our doors off? I messed with my doors for the past few months and ill tell you, im amazed our doors even stay on. Its just two little c-brackets with a hinge in the middle. Search recylclers please before you pay that ridiculous money for them! They look like they could make a profit if they sold the entire assembly for $5. There are so many recyclers with lower mileage cars. And the pins never actually go bad (so a few different body shops have told me). What happens is due to the weight of our door, our doors sag no matter what you do. If you dont correct the sagging in time, you end up damagind the pin by forcing it into place so many times. Like you said above, your door drops and then you slam it. You never thought of maybe taking it to a body shop? They adjust the door in about 15 minutes, it costs 50 bucks and your good for another 2 years. Shuts better than factory. But now that its got to the point you have to fix them, id recomend replacing the bushings first. Usually fixes them. BUT if you want to replace the hinge, i recommend going the recyclers' route.
Old Feb 23, 2009 | 08:49 PM
02gtp4now's Avatar
my door does the same as the op's it's not an adjustment problem mine does not sag, just the roller pin has a flat spot on one side that catches and makes it hard to shut
Old Feb 24, 2009 | 06:10 PM
hempkat94z's Avatar
Mine has the flat spot but I have no problem shutting the door and it doesn't even sag. It just makes a loud *** noise when opening. Here is the pic.
Old Feb 25, 2009 | 11:21 AM
cvalliere's Avatar
Like I said before nothing on the hinges are serviceable. Either go to a junk yard and get some or go to the dealership and get new ones.
Old Mar 4, 2009 | 08:38 PM
nebur8's Avatar
OP i have the same flat spot as you do and have not got around to fixing it. However, i coat that wheel where the flat spot is with white lithium grease spray in there every few months and it stops. Not a permanent fix but it works!
Old Mar 5, 2009 | 11:35 PM
hempkat94z's Avatar
ok thanks. I found a donor car that I am going to be pulling it off of.
