oem paint in a can?
Old Feb 24, 2009 | 11:27 AM
silverz28camaro's Avatar
Default oem paint in a can?
Hey guys, im wondering if there is a perfect or near close oem paint match in a can for my 2000 sebring silver paint.
I have a few spots on the rear that i would rather touch up for $10 rather then painting them for $$xxx amount. I will have the entire car painted in a few years to come, but i was waiting on the rest of the car to need it first, plus i want to buy a house with a garage before I spend the money on a fresh paint job.
I went to the local parts store and they had a few silvers, one was close, but i was wondering if there is a better temporary match.
Old Feb 24, 2009 | 11:31 AM
NeedaV8foundation's Avatar
duplicolor... its sold at autozone, walmart, ect.
Old Feb 24, 2009 | 12:06 PM
Yeah i found all types of duplicolor about 10 different silvers, just no sebring silver, mayby ill try a different parts store, or look on their site, Are you sure they have sebring silver match?
Old Feb 24, 2009 | 12:21 PM
02SS0384's Avatar
Did you look up your paint code and match it to the Duplicolor product? Also you can go to the dealership and get some from the parts department.
Old Feb 24, 2009 | 02:01 PM
shaun's Avatar
you should be able to get it from the dealer.
i think duplicolor makes it just check on there site.
Old Feb 24, 2009 | 02:49 PM
SSJIMMY's Avatar
autobarn.com is where i get mine
Old Feb 24, 2009 | 04:30 PM
Ricer's Avatar
properly matching silver in touch-up form is very difficult.. the metallics won't lay down right.. usually causing a darker color once its dry.. even if you get the proper color code
Old Feb 24, 2009 | 07:45 PM
the_bandit77's Avatar
I was told that you can take your code into NAPA and they'll put it in a spray can for around $15.
Old Feb 25, 2009 | 01:09 AM
Thanks guys, i searched duplicolor web site, but found no direct link, i would have to call them, i may try the dealer, or call napa, either way i know it wont be perfect but i want to get rid of the primer that is on there now.
I will let you guys know how it turns out and post pics when i get it finished for the time being
Old Feb 25, 2009 | 06:41 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Most paint shops can mix the color and put it in a spray can.
Old Feb 28, 2009 | 12:51 AM
8675309's Avatar
I usually go to sherwin williams and get mine, but the others are probably good too.
Old Feb 28, 2009 | 12:56 AM
99bowtieZ's Avatar
I know o'reillys will put it in a spray can... Not sure how much it costs though.
Old Feb 28, 2009 | 05:58 AM
evilZO6's Avatar
Go to any Auto Piant supplier. Tell them the year and color of your car, they digitally mix it and put it in an aero-can. BUT, its not going to be an exact match. Silver is tough as is but spraying it in a different technique effects it too! Your best bet is to have it blended by a professional becuase if you try this, and it doesnt work, your going to be kicking yourself in the *** for having a big dark spot on your car and eventually you'll just have to go to the professionals anyway. I've never seen a direct match from a spray can . Even white, on a good friends honda, didnt match.And thats Honda's white, simplest paint you can buy. Plus its a single stage compared to dual stage. You can add a clear, but in order to be in a can it has to be single stage, or so 3 years ago when i bought it last it was like that. Just get your whole car a fresh respray-its affordable if your staying the same color cause they just clean it, scruff it up, and spray. No door jams or anything!
Old Feb 28, 2009 | 02:58 PM
4150's Avatar
paintscratch.com is another source, I've bought touch up paint from them before and it was much nicer than anything I've ever gotten from duplicolor.
Just dont spraypaint it, you'll have a really hard time blending it in with the existing paint...especially with silver.
