Bumper Repair
or why not have insurance pay for the damage, teaching plastic repair online is impossible with out you being there to watch it, could i tell you how?? sure can but its difficult online
I did not find any damage underneath I think because of the way I impacted the bumper was pulled sideways and not smashed in. The impact marks are just scrapes no cracks like I would expect from being pushed in.
I used some ABS/Metal epoxy to reset the bolts as well as I could. I then cut a grove in the crack on the support and filled it with epoxy and put a strip of sheet metal across it and epoxied over that. After 3 hours I think the bolts are now better attached than they were originally. And i can not flex the support it is as rigid as the rest of it.
The final test was reinstalling the cover and associated parts, I think that was the hardest part because I had to find enough plastic rivets to put it back on. Everything lined up very well and the crack is now only about 1/16" wide. The gap between the bumper cover and quarter panel on the passenger side is a little wide about 1/8" too wide at the rear of the bumper but it is not noticeable unless looking for it.
I decided to work on the front damage yesterday and after removing the headlight and signal lamp I was able to hammer it out almost to the original shape, which once again if you don't look for it you can't see it. There is a small tear in the front bumper cover at the back corner of the signal lamp but once I hammered out the dent and put the lamp housing in the crack is sealed up and can be easily fixed.
I think that I am going to see about getting a body shop to fix the rips and the front will need some new paint. But overall I am fairly impressed with the results for a first timer in a parking lot. I will post the before and after pictures later when I can access my camera. There is a pic of the front end in the Texas section. https://ls1tech.com/forums/texas-mem...y-bumpers.html
front bumper need to be replaced, and looks like the right fender is tweaked in to
i guess for a quick fix its not to bad, but its still not right and something looks wrong
like the energry absorber is it damaged, re-bar, rear body panle
but hey if your happy ri ght
