Rim paint
Old Feb 6, 2010 | 08:57 PM
Raptor_WS6's Avatar
Default Rim paint
what type of paint do you guys use? i want to paint a my tt2 spokes a different color...
whats best for it
Old Feb 6, 2010 | 09:11 PM
poltergeist 02's Avatar
take them to a shop.
Old Feb 6, 2010 | 09:34 PM
Raptor_WS6's Avatar
ok. anyone that can read
Old Feb 6, 2010 | 10:19 PM
JCattSS's Avatar
I used the duplicolor wheel enamel on my winter wheels. They have only been on with the paint since about November but so far they are holding up great. I sanded them, then one can of self etching primer, then about 2 1/2 cans of paint. I run it through the car wash and drive every day in the snow/salt. Not the best pic but they turned out a lot better than expected.
Old Feb 7, 2010 | 02:40 AM
crimson_bird's Avatar
^screw winter, id be rolling on those year around. that thing looks mean with them on there.
Old Feb 7, 2010 | 09:32 AM
omarrakeen's Avatar
i have 4 BMW wheels a friend gave them to me lol i painted them using car body paint which i had around...i painted them grey i used hardner or wtever u call it, grinded the rims and paint...ill post up a pic not the best one i have but hope this help...
Old Feb 7, 2010 | 11:55 AM
fbdy4life's Avatar
if your just wanting to paint to make them look decent then just use autobody paint and clearcoat. however the problem with is that there is no autobody paint/clearcoat that is immune to rockchips. so with in time your wheels will look as if they have a bad case of acne. i would honestly recommending powercoating. most good looking wheels that are painted are powdercoaded which keeps them nearly damage free. just my opinion.
Old Feb 7, 2010 | 02:50 PM
Raptor_WS6's Avatar
yes they will eventually be powder coated... but for now, paint will do
Old Feb 7, 2010 | 02:56 PM
hlaalu's Avatar
you people who say "take it to a shop" for every little thing are so freaking annoying. go take your comments to a shop.
to actually answer the question,
i used duplicolor engine enamel w/ceramic. holds up to heat and grease quite well. if you go black, use a black primer. make sure you prep it really well, but i'm sure you already know that.
Old Feb 7, 2010 | 05:10 PM
Dupli-color makes paints just for wheels, so instead of using other stuff, i'd recommend that.
Old Feb 7, 2010 | 06:30 PM
FastRidesOnly's Avatar
i'm gonna use car paint on my rims for my 2 camaros..
about to paint a 92ranger black.
so while i have the gun full of paint.. i'm gonna spray the 2 sets of stock rims but keep the aluminum lip
Old Feb 8, 2010 | 11:37 AM
black_sheep454's Avatar
Either use a base/clear, or duplicolor acrylic enamel. I've had good luck with both but base clear will give you a better shine but takes more time money and talent
Old Feb 8, 2010 | 12:13 PM
if i had known that you are planning on powder coating them later on then i would have said just use duplicolor. if you want it to last then you would want to use ppg or dupont. didn't meen to leave a comment that makes me sound like an a**.
Old Feb 8, 2010 | 12:26 PM
you don't know me and i don't say take everything to a shop to get the work done. i made that comment assuming that he wanted them to look nice and last a long time! you shouldn't go jumping up everybody's a** that leaves a comment to take something to a shop to get it done the right way! it' just an opinion for christ sake! if you don't like my opinion, then just move on. i can understand leaving a quote like that if i had actualy given some bad advise!
Old Feb 8, 2010 | 08:00 PM
kwiksilverz28's Avatar
Shopline acrylic enamel
Old Feb 10, 2010 | 07:01 AM
masterz28's Avatar
I wanted to paint my wheels too raptor, but everyone says just powder coat them. Meh, the only concern I have is what type of preparation needs to take place, for instance if the wheels are Chrome or polished, or painted already. Do we just sand it down? I heard sand blasting wheels makes them weaker, that sounds ridiculous...I would go with Dupli color
Old Feb 10, 2010 | 07:51 AM
Tbird232ci's Avatar
I've used Duplicolor wheel paint many times with great results. Take your time, make sure everything is clean, and you will have good results.
Old Feb 10, 2010 | 04:47 PM
1slowgoat's Avatar
i used auto paint on my wheels
Old Feb 10, 2010 | 05:06 PM
Mr. Trick's Avatar
I did the samething with my stock wheels and it held up real well. Like mentioned just prep the surface good.
Old Feb 10, 2010 | 11:10 PM
rabbit320's Avatar
something different!!! i heard bad stuff about duplicolor wheel paint, check out in a rattle can: Epoxy paint for Appliances, comes in black and white at home depot, works awesome, used it and loved it, nice gloss, heat resistance, scratch resistance...
