To shave or not to shave?
The work involved is really not an issue its just a question of will it be worth my time to fill in the holes for the end result?
What would you guys do? The car is Mystic Teal and I plan on keeping the factory color if that helps.
Who else? So far that's one for no.
so does that car look "rice" to you?? shaving hanels or custom work isnt just for imports one custom shop i worked for that was a given to shave handles, it looks great cleans up the look of the car
the color of your car doesnt matter its still going to cost you allot of money to do a complete paint job, plus you have parts that are going to require allot more work which mean more labor which mean more money
starting price where i work would be 3,000 and it goes up from there, just keep that in mind when your shopping for a price
I have already set up a price with a local body shop to have it painted for very cheap. I wasn't asking what it would cost to do it since I am doing all the body work on the car myself. I was just trying to get my fellow LS1 Tech guys to help me decide if I should do it.
1) it cleans up the look quite a bit.
2) if you use the remote, you never need the key hole. the key holes on my camamo have been covered with smooth lock covers (http://www.smoothlock.com/) for over 3 years now- no problems. i figure i might as well shave them
3) this is MUCH easier/cheaper than shaving the whole thing. other than the cost of the filler, and your labor, this is a FREE mod. if you shave the door handles, that cost several hundred dollars to get the solenoids and the whole set up to pop the doors open. much more work/money -personally i dont think shaved doors look bad/"ricey" at all. when i think of shaved door handles, i think of old-schools, low-riders, show cars, etc.. not imports.
4) like you said, if anything goes wrong and you cant get in through the door, go in through the back. and get your door fixed asap. and ALWAYS have a spare set of keys. which you should always have anyways
inside the kit there is a emergency button, that hooks up to the brain box, and even if the battery is dead the button will still pop the door open
and it work on less then 4 volts, or some guys just install a cable and we just hide it so no on sees it
i use spal kits never had a problem, very easy to install
The filler I am using is Putty-Cote I found from Oriely's auto. It has the blue activator. This stuff really spreads out nicely and sands glass smooth.
shaving the door handle requires a lot of work/money to do the whole set up for remote door poppers and all of that.
