Door skin coming undone.
for the front there is a rivet that holds the top of the skin to the door frame on the hinge side at the top. push the door skin in and you will see it after you remove the mirror triangle frame and belt strip...just fixed mine the other day. I used a 10mm bolt and nut as the rivet hole was a little out of whack. i suppose you could take the door off and use a larger rivet but i figured the bolt would be easier and in some ways a better fix. its an easy fix. took me 20 min. the rear will nee glue.
The following users liked this post:
derekpaw24 (05-08-2023)
Fixed!
It's pretty self explanatory once you have your tools/equipment ready.
