Painting T-Top Divider
Don't really want to paint it while its on the car... Removed all the screws to find out its glued in also. Anyone have any luck removing easily this piece.
Grab some 80lb "spider wire" fishing line as its not metal or thick like original fishing line and tie each end to something comfortable for handles and pull... will be easier when its hot outside and the surface is hot to the touch
I love how ppl who have never done this offer "advise/knowledge" on how to go about doing so. damn fools.......here u go OP
https://ls1tech.com/forums/appearanc...t-top-bar.html
Dude, we've pulled tons of these for the Targa creation. Just pull out all the screws and grab a corner and pull up slowly. You wont hurt anything. It's just a double sided tape that holds it down on there.
If you use the fishing/piano line, you'll cut the tape and it wont stick anymore. After you pull the piece up, you'll see that the tape will still be sticky, just make sure you remember what side is the front and then re-stick it with the holes lined up. SUPER EASY. I learned at the junk yard then on our cars.
Just take your time bro.
I'vr done this 3 times now on 3rd gens and I sure its no different on a 4th. its just 2 sided adhesive of some sort which if you pull it enough it will come apart. I pulled mine on my 85 to clean it up and ended up using tremclad rattle can high temp paint as I didnt want a gloss look at all. Make sure you use a Hi temp paint as its gonna see some hot days LOL. I used a crap load of RTV as well when I put it back on to make sure it would never leak again and it never did. When I parted out my 85 someone wanted the bar and when I took it out. WOOO It was on there after I was done. I got some pics ill post here
UNDERNEATH
NEW PIECE WITH NEW SEALS
UNDERNEATH
