painting engine block?
Old Mar 26, 2011 | 04:55 PM
Marcello7x's Avatar
Default painting engine block?
So how do you guys usually go about this? I have a bare block that will be going over to the machine shop for assembly, do i paint pre or post assembly? I figured post since it would get all scratched and chipped up while there. Especially if they need to machine it a little extra.
Old Mar 26, 2011 | 05:05 PM
jim ravencraft's Avatar
Hi,
we paint everything prior to final assembly. However you can paint prior to install. Use a quality paint/primer for higher temps. Proper cleaning and prep work a must for quality job. Tape everything with frog tape to prevent bleeding on adjacent areas...good luck and have a blessed week.......jim
Old Mar 26, 2011 | 05:14 PM
Marcello7x's Avatar
thanks for the advice jim
Old Mar 29, 2011 | 08:15 PM
Commissar's Avatar
Prior to full assembly. Basically just had the heads on, no accessories, intake... Think it came out ok. Used a lot of degreaser, just sprayed on duplicolor engine enamel. After a couple years it is still holding up good. Exhaust ports were still masked off in this picture. Best way I found to mask areas is to mask the area, plus additional, place the gasket in place, then trim around the gasket with a utility knife.
Old Mar 29, 2011 | 10:19 PM
AutoRodTechnologies's Avatar
I like the color.
I always spray with epoxy then color then clear, had good luck doing it this way.
Old Apr 4, 2011 | 12:48 AM
01ssreda4's Avatar
Dupli-color engine paint
Old Apr 4, 2011 | 03:12 PM
6SIX6's Avatar
Wow thats a first time ive seen a coulour like that. I really like it for some reason as its different.
Old Apr 4, 2011 | 04:24 PM
Tbird232ci's Avatar
It does look good.
Not really different, it's Pontiac blue like used in the muscle car era.
Old Apr 4, 2011 | 08:53 PM
Commissar's Avatar
yeah, color isn't new. Here it is in an old GTO
Old Apr 5, 2011 | 03:27 PM
Tbird232ci's Avatar
Did you get the engine in your picture in the car? What color is the car?
Old Apr 5, 2011 | 08:45 PM
Commissar's Avatar
Not the best pictures... Car is Brazen Orange Metallic
