Do I need a new door?
Old May 2, 2011 | 06:28 PM
SmokedOutZ28's Avatar
Default Do I need a new door?
I fucked up..... Results
Can this be fixed or will the door need to be replace? I know the hinge is loose and the door sagged a tiny bit but now this is the icing on the cake! I don't plan to do it myself just curious so I can prepare myself for the worst. Thanks
Old May 2, 2011 | 07:31 PM
BGMZ28's Avatar
Currious to know too, my door as the same damage. How did your door get like that (bought mine with the damage)?
Old May 2, 2011 | 07:38 PM
ringmaster72's Avatar
Has the outer skin separated from the door or is it just banged up on the end?
Old May 2, 2011 | 07:41 PM
egott_91's Avatar
Wtf did you do Sam? Ha.
Old May 2, 2011 | 10:43 PM
No it hasn't it's just banged up at the end. kinda smashed in.
The car door caught the metal frame of the garage door. It rolled when I didn't set the ebrake while loading a tune. Stupid mistake that will probably cost me a new door and hinge since it seems to be harder to open now.
Old May 3, 2011 | 02:46 PM
You would just have to fix the edge with bondo, blend the black and clear the whole door. The only problem is I dont think I would want bondo on the edge of the door though. As far as the opening of the door, the hinge is probably bent a little, but you should be able to bend it back. It is hard to explain, but you can use a socket and wedge it in the door hinge and start closing the door, this will bend it back.
Old May 3, 2011 | 07:55 PM
Grr's Avatar
Grr
sand out the edge and fix with fiberglass, not a big deal to fix and easy to change the hinges too
Old May 3, 2011 | 08:54 PM
Thanks guys. If it's not gonna be a big deal then I will just let them fix it vs replacing it. The shop I'm going to use has a 5 year warranty against all body work and paint so either way unless they go under I'm good if it falls apart.
