Plati Dip? WTF?
Old Mar 11, 2012 | 11:36 PM
  #241
sam23's Avatar
Originally Posted by autogeek23
I'm in between on doing the sail panel. I did the ceta mod in plastidip. Thanks for having a red ta and doing it. I might.
i didnt think i would like it, but i think its just something different and if u dont like it peal it off.
Old Mar 12, 2012 | 07:05 AM
  #242
autogeek23's Avatar
Very true. How many coats did you do? On my ceta I did 4 and followed the directions on the can. Did you get any runs if you put it on heavy at first? I kept it light so it didn't run if this stuff runs.
Old Mar 12, 2012 | 09:09 AM
  #243
disc0monkey's Avatar
this stuff is really easy to lay down. if you get a run wipe it real quick and hit that spot only next time to fill it. make the next coats real thick and dont wait long in between coats to fix. this stuff melts a good amount of the previous coat under it so even if you mess up the next coat will usually fix it.
Old Mar 12, 2012 | 09:35 AM
  #244
Originally Posted by 99wssixm6
I think there is alot going on here that needs to be discussed. Did you plasti dip the black bird stripe? If so I/we need some info on how you did that. It looks freaking sweet. I had those stripes but since my hood has been repainted I flying bare.
Please tell us how you did that.
sorry I didn't see this post. I bought some pin stripes at autozone. the one with the thin stripe, and then a thicker stripe on top of it.
Run the pin stripe with the thicker stripe towards the center of the "black bird stripe". Stick the stripe on the back of the hood towards the windshield and eye balled the stripe along the curve of the hood.
I bought a bunch of "ram air" stickers on ebay for cheap. Peel off the ones that were on the car because they are too difficult to take off when the paint is wet.
Wax under the ram air really well
Now LIGHTLY install your new ram air decal. like barely push down on them
Now run masking tape along the outer strip of the pin strip and setup your news paper along the outside of the stripe.
Do one side at a time.
Do not do this in the sun.
spray a nice light first coat.
next coat will be as thick as you can go before you get a run.
As soon as you see the paint form a skin this should be like 2 minutes.
you wait too long you will not get a sharp line you made with the tape.
you don't wait enough your paint will bleed over the line.
Once you think the paint is at the right state, you have to do this all really fast.
Start tearing all the masking tape and pin striping off without it touching the paint. then take a razor if you got kahoonas or a pastic wedge or something and peel the ram air out.
Like i said you have to hustle during that part. but you'll be left with a nice stripe than peels off when you're done with it.
Old Mar 12, 2012 | 09:43 AM
  #245
Guitar's Avatar
Very well done.
Old Mar 12, 2012 | 11:18 AM
  #246
therobman's Avatar
i was planning on doing my sail panel in black but does this stuff actually last or will it be peeling off after a few washes
Old Mar 26, 2012 | 09:06 AM
  #247
it will not peel off during washing
Old Mar 26, 2012 | 08:56 PM
  #248
FastRidesOnly's Avatar
i thought of doing stripes with plasti dip. i have a roll of matte black vinyl.
i'm not good at using tape with plastidip though. i tried it and messed it up. the tape peels the plastidip off when i remove it. i think i read i'm suppose to remove the tape while the plastidip is still wet. any advice?
Old Mar 26, 2012 | 09:00 PM
  #249
JUSTINSWS6's Avatar
Best thing i ever found what plasti dip wil do is the rear quarter panel for the track so the tire and tar will peel right off. Do they make it in white?
Old Mar 26, 2012 | 09:04 PM
  #250
autogeek23's Avatar
i did plastidip for my ceta mod. while moving my exhaust under my car and out of the way i knicked the ceta mod and chipped it. im gonna try to respray the chipped spot and blend it so it looks good.
Old Mar 27, 2012 | 06:44 PM
  #251
WS6 What's Avatar
white/black/blue/red, i think,
Plasti dip is cool, try it out and if dont like it, peel it off. Love the stuff.
Have you seen the whole cars they paint w/ this stuff. Kind of cool.
Old Mar 27, 2012 | 11:21 PM
  #252
i wnna do this
Old Mar 28, 2012 | 12:11 AM
  #253
Streetlegal?'s Avatar
Yes you are supposed to peel the tape off while it is still wet otherwise the platidip will just peel off. When you peel it off make sure you peel it away from what you are painting and not straight away from it otherwise you can make it peel like that too.
Old Mar 28, 2012 | 12:17 PM
  #254
buellxb12s's Avatar
Guys check out dipyourcar.com. you can get custom colors buy it by the gallon. The offer silver and gold metallic colors as well as a glossifier to make the plasti dip gloss rather than matte.
Old Mar 28, 2012 | 12:33 PM
  #255
SS/CETA's Avatar
I've used this stuff on my Impala wheels which are polished and it looks great. Cleaning helps for sure, and the many imperfections and curb rash I have on the wheels are hard to spot with the plastidip application.
I used 2 cans for my wheels about 7 months ago, and they're still holding up pretty well. The flaking has started around the lip of the rim, but not so much on the surface of the rim itself.
Old Mar 30, 2012 | 03:59 PM
  #256
FyreLance's Avatar
I have a set of chrome AR rebels that are pitted on the lip... starting to wonder if it would do a good job of covering that up.
Old Apr 7, 2012 | 02:25 PM
  #257
Furious1's Avatar
Just plasti-dipped the CETA mod. I have a few runs, which I figure cant be fixed. It looks good though, you cant see the imperfections unless you are right on top of it.
Old Apr 9, 2012 | 08:28 PM
  #258
christiandoy's Avatar
looks great!
Old Apr 13, 2012 | 12:28 PM
  #259
whoring her out last time for a outside view
Old Apr 13, 2012 | 06:18 PM
  #260
Mtownls1's Avatar
the plasti dip is crazy awsome! i did my trucks grill and few other things.i went on the site they have and ppl are doing their full cars..not cheap cars either and they look awsome..im thinking about doing my little junker car that i drive to work becuase its all sun faded and crappy looking i wonder what how the red with clear over it would look like and how long it would last as a whole car that sits outside all day 365 a year..lol guess it couldnt look worst then wat it does now..or even the flat army green with black wheels with gloss over and tinted tail lights!! its a 97 eagle talon btw. guess i found a new project lol
