Plati Dip? WTF?
Old Apr 14, 2012 | 01:41 PM
  #261
FinallymyT/A's Avatar
I was researching doing the ceta mod to my '99 arctic white T/A and stumbled across this epic thread, reading every page. Going to buy some plasti dip today to do the ceta tomorrow.
Any advice for taping up the round corners on the ceta so I can get the tape off quick without tearing the plastidip?
Great thread!
Old Apr 14, 2012 | 06:05 PM
  #262
Furious1's Avatar
Try to do the taping with one long strip, slowing guiding it along the groove. Go get some half inch think painters tape, that will make it easier to get into the groove and guide around the corners. Make sure to not spray too close or too thick right off...you will get a few runs (like me.) Luckily, once dry, they are hard to see. You need to work kinda quick, so you can remove the tape before it starts to cure. When peeling the tape, pull at a 45 degree angle away from the edge.
Old Apr 15, 2012 | 04:05 PM
  #263
Just finished the CETA mod using plasti dip about an hour ago. Looks great! I did fudge the corners a little, but not too shabby for my first time "painting".
I set up a mini-paint booth in the garage by just barely backing the T/A in, and using plastic sheeting to seal up the garage opening to eliminate overspray.
I did only get two thick coats out of 1 can. Will this last? Thoughts?
Old Apr 15, 2012 | 04:35 PM
  #264
Furious1's Avatar
Yea, it should last. Quick tip-pick up some black pinstripe to run in the groove to clean up any edges.
Old Apr 15, 2012 | 04:49 PM
  #265
Thanks for the reply Furious. I sprayed into the groove, had my tape on the outside edge. Overall though, I'm happy with it. She's 13 yrs old, not a show car, and I'm on a budget. Kudos to ls1tech.com for allowing us a place to help each other out with stuff like this!
Old Apr 16, 2012 | 12:30 AM
  #266
323steel36's Avatar
Is this plastdip stuff safe on chrome rims?
And do i need to buy any adhesive or do I just spray the color of my choice to the rim?
Old Apr 16, 2012 | 04:27 PM
  #267
ls1jorge's Avatar
^it's 100% safe to use on paint & any type of wheels, it won't hurt or leave nothing stained & its easy when removing it, just simply rub off, Since your painting your wheels I'd suggest have them clean, wash & wipe off all the road dust, Completely Dry it & Spray, "Search Youtube: Plasti Dip" & it's known to hold up very well when washing at the car wash, I plan on doing my rear bergel panel for my Camaro.
Old Apr 17, 2012 | 11:03 PM
  #268
323steel36's Avatar
Well I am going to get my car detailed so should i ask them to polish my rims or just clean them? Will the paint stick if my rims get polished before I add the paint?
Old Apr 19, 2012 | 01:15 PM
  #269
ls1jorge's Avatar
Go ahead & get your car detailed and the rims so after it's done it'll be cleaned & ready for spray
By Brett Foote | 2026-06-04 05:00:17
