is it possible to adjust the rear hatch/quarter panel gaps?
i've noticed my car, (and a few other trans ams) have a larger gap on the drivers side between the quarter panel and hatch than on the passenger side,about double the size. Needless to say i want to adjust it but i don't really see any way to do it. any insight is appreciated
Same here would like to know also, I had that issue with both my ta's and want to even them up. The one guy who did his build thread with the red formula ws6 lt1 that converted it to a silver trans am clone may know how to fix this since he fixed every gap issues on his...
You can try to loosen the nuts on the hinges but theirs not alot of adjustment I believe, if you can't get enough adjustment take the hinge and use a burr bit and make the hole bigger then adjust. After you get it where you need you may have to adjust the striker.(this is all from memory about 2 years ago when I adjusted mine on my old camaro) good luck
