Why does this rattle can paint job look so bad? Pics inside
I helped a buddy paint his FAST intake manifold. We sanded it down, cleaned it off, then sprayed some brake cleaner to get any of the remaining oil off.
He bought three cans of VHT High Temp engine enamel from Summit, and the thing wasn't going on right. It looked nice once you sprayed it down, but after about 10 minutes it started to turn colors. At some parts it looked nice, while at others it would turn a whitish color. With every coat, another part of it would look like crap. So with every new coat, the parts that previously looked like crap would look good, but then other parts would start to look like crap..After about 6 coats, I said no more..
I found an old Ace Hardware rattle can in my garage..Sprayed the intake down, and it looked 100% better after only the first light coat. Second coat, it looked perfect..Before and after pictures below.
So now I ask you..Whats up with the VHT rattle cans. Are they junk, or do they just need a primer below them to properly work? We shook them up real good, so I dont think thats the issue. It wasn't my first time using a rattle can lol..
The VHT results.
The Ace hardware rattle can results I found in the garage, probably a couple of years old.
The VHT results.
I figured it was the humidity, plus the ace paint is a flat type of finish, gloss or clear coat spray bomb is more likely to do it then the flatter looking paints, I've never used either brand.I always use wurth spray paint it does nice but even it can blush(turn white with high humidity) just keep that in mind if your needing to do something in a gloss finish with spray bomb. Still looks good with the matte finish though!
It was definitely the humidity that caused the white spots, but the black you laid down last turned out great! I've never used VHT other than their Nightshade. I used duplicolor high temp rattle can, high build primer, and High Temp Clearcoat on my intake. It was a little humid so I had some white spots like you did but after painting I brought it into the house so it would cure and it went away. It's a cell phone picture and it looks grainy but after tons of wet sanding and polishing, it came out great.
going to throw my vote at humidity as well. one of the most overlooked aspects of a paint job is the environment your painting in. also, as someone already mentioned .. brake cleaner isnt the best paint prep chemical.
ive done the samething as you and figured out that it was the damn brake cleaner, brake cleaner is strong **** it will just soak into the plastic never use it again. just use soap and water and a hard bristle brush to clean the intake.
Old School Heavy
Your first pick looks like solvent pop. Humidity, contamination, temperature difference between the part, the air and/or the paint can. To close or too heavy can do it too. This time of year can be tough. Do it in a heated garage that has been heated for a while to kill the humidity. Clean the part with mineral spirits and make sure it is completely dry. Let the part, paint and air all equalize in temp and keep the coats just light enough to look wet and let it have sufficient drying time between coats.
Also, old paint can screw you.
The key to any good paint job is prep and using brake cleaner to prep is a terrible idea especially if it soaks into the plastic or puddles in somewhere in the intake because the paint will lift or fisheye.
You also need to give the paint something to stick to and a great primer is perfect for that and will help greatly with helping the longevity of the paint to last as well. Do yourself a big favor especially if you are planning on painting that intake again and use a very good primer and make sure you have all that old paint covered before you try and repaint it again and maybe head to a quality paint shop and see what sort of colors they offer in a spray can and try again.
