painting a fast intake...
Old Aug 9, 2011 | 02:25 AM
UnVMySS's Avatar
Default painting a fast intake...
Got a brand new fast 92. Want to paint it black with red lettering. Would I be able to powdercoat it or should I paint it?a little worried about trying to use a $5 can of spray paint on an almost $1000 intake.
Old Aug 9, 2011 | 09:37 PM
LilJayV10's Avatar
When I painted mine I used PPG adhesion promoter and SEMS plastic paint. I then used a paint pen to do the letters. Make sure you clean it really good first. The plastic can suck in oil and other contaminants.
Old Aug 11, 2011 | 04:31 PM
Conrad's Avatar
Just wondering where you got your "new" fast 92?
Old Sep 4, 2011 | 05:47 PM
01 WS6 6.0's Avatar
Im thinking of doing the same thing i googled it give you different methods and paints people used
Old Sep 4, 2011 | 06:17 PM
LS1powerd's Avatar
I have the same issue.
Old Sep 4, 2011 | 07:34 PM
LPE 403's Avatar
Paint can is fine. Do your prep, you wont have any issues.
Old Sep 4, 2011 | 08:22 PM
zacht's Avatar
i painted mine with rustoleum plastic paint "textured" black. only had the idea because i had to paint some post coverings for a house with it, and it stuck well to pvc. so far its holding up great! and it looks just like a stock ls1 intake!
ill try and keep you posted on how it holds up!
also i scuffed it, and hit it with paint thinner (all i had) dried good, then hit it with the whole can (6-7 light coats)
Old Sep 4, 2011 | 11:15 PM
JOHNNY59's Avatar
there is powder coating made for plastic.you would be better off in the long run.
Old Sep 7, 2011 | 10:56 PM
SilverGhost's Avatar
Motorboater
Same powder that we use on metal actually, just different method of application since there's no electrostatic assitance.
Old Sep 7, 2011 | 11:14 PM
BoricuaHec01's Avatar
Formally Simplɘ Jack
^ Now that's a powder coating expert.
Old Sep 9, 2011 | 11:21 AM
kingd_202's Avatar
Same here...
Old Sep 23, 2011 | 10:43 PM
BrntWS6's Avatar
Can you powder coat to a specific paint code?
Old Sep 24, 2011 | 08:51 AM
H.O.H11's Avatar
if u go the paint route i def wouldnt over look the prep that will make all the difference. i would use a good adhesion promotor and epoxy sealer then color. thats an expensive intake to take shortcuts.
Old Nov 19, 2011 | 10:32 AM
SoonerC6's Avatar
Not sure what you decided, but I did mine just how you wanted. Black/red... I used spray paint for plastic from autozone. Turned out great. 2 coats adhesion promoter, 4 coats black, 3 coats clear, and a red paint pen.
Old Nov 21, 2011 | 07:08 PM
ctjohns's Avatar
Nice job
Old Nov 23, 2011 | 07:04 PM
02ws.sik's Avatar
im want to get a bbk intake and paint it white with black letters, but im afraid it would always look dirty.
Old Nov 25, 2011 | 07:20 PM
camaroboy14's Avatar
Looks great !!
Old Nov 25, 2011 | 10:16 PM
lethal bird's Avatar
Soonerc6 that intake looks like teh sex!
Old Nov 26, 2011 | 03:37 AM
TruBloodTransAm's Avatar
What are you guys using to clean it with? Mine's got some oil stains on it too.
Old Aug 16, 2012 | 04:38 PM
Turbo306Fox's Avatar
Should I use regular dupli color black or like a heat resistant engine paint
