Clear Coat is Gray???
Old Sep 29, 2011 | 05:35 PM
LS1121's Avatar
Angry Clear Coat is Gray???
Ok so i took the separator off between the t-tops and painted it with rattle can paint and it looked good. Then i applied 3 coats of rattle can clear and it looks like ****, it looks kinda gray what happened??
Old Sep 29, 2011 | 05:39 PM
Maroboy's Avatar
what brand did you use on the clear coat?
same thing happened to me, that was the first and last can i bought after that
Old Sep 29, 2011 | 05:51 PM
LS1121's Avatar
I used Dupli-color Lacquer black and clear.
Old Sep 29, 2011 | 05:56 PM
Maroboy's Avatar
i dont remember if i used rust oleum or duplicolor.. but same **** happened
that sux man.. i know how u feel..lol
Old Sep 29, 2011 | 09:35 PM
LS1121's Avatar
Does anyone why this happens?????
Old Sep 30, 2011 | 01:46 AM
CS2 Sasuke XD's Avatar
I know when you use some clears in too many coats it'll start to haze out. looking gray over dark colors or white over lighter colors. Try wet sanding it. If that doesn't work then damnit.
Why it's caused? I don't remember but I only do On coat of clear always to prevent this.
Old Sep 30, 2011 | 08:33 AM
LS1121's Avatar
Thanx I will try that.
Old Sep 30, 2011 | 10:32 AM
FSTR/TA's Avatar
SOunds like too muuch clear was applied at one time. You should do it in about 3 coats all being a medium wet coat. Not a heavy coat as that is what whites out. That and use the same company for paint and clear. Some may not be compatible with each other.
Old Sep 30, 2011 | 10:50 AM
LS1121's Avatar
I think I did it in 4 very light coats. Just enough for it to look wet. It started to rain when I was doing it in my garage do you think that had anything to do with it?
Old Sep 30, 2011 | 12:31 PM
Swiat34's Avatar
Those cans of clear don't do will with natural humidity. Spray the clear on and bring it inside your house and have your heater or AC running. If it's dried like that now, you'll have to re-apply color then the clear again. Then like I said, bring it inside for a couple hours.
Old Sep 30, 2011 | 12:33 PM
birdhoss's Avatar
Sometimes when there is high humidity that makes the black haze up and look gray then when you cleared it was over that hazed gray look. Laquer in rattle cans will do that. Try again when it is a dry warm day.
Old Sep 30, 2011 | 03:30 PM
LS1121's Avatar
OK I have some 400 sandpaper, i will hit it a little and then go again. The black looked really good, I put on 6 light coats and it was Black. it was definitely the clear that made it look gray. I will try again tomorrow. Thanx to everyone for your input.
