High temperature exhaust paint, what works best?
What's available besides VHT high temp?
I use to get Dupli-color 1200* and it worked good, but I can't find it any more.
What do you use/recommend?
FYI, I'm not using it on headers just further back on the exhaust.
Thanks
Thanks
I have used VHT in the past but the spray top things they use are junk. I have had a couple stick open and loose half the can of paint.
I normally use high heat rustoleum in flat black. It is $9 from autozone and have used it on full exhaust systems to turbo manifolds and it works great. Just run it though a couple heat cycles like it says on the can and you should be good.
