Rocker Panel Repair help!
Old Jun 24, 2012 | 01:56 PM
Rated Z's Avatar
Default Rocker Panel Repair help!
I sort of had an accident with my 02 Z. I scratched and dented the driver side rocker panel. They seem pretty cheap for a new one. My question is how hard is it to remove the outer rocker panel and replace it with a new one.
Old Jun 24, 2012 | 02:14 PM
Rated Z's Avatar
Default This is what happen
i play on ordering prime,paint,and clear coat for the new rocker panel.
Attached Thumbnails Rocker Panel Repair help!-img_0421.jpg   Rocker Panel Repair help!-img_0422.jpg   Rocker Panel Repair help!-img_0423.jpg   Rocker Panel Repair help!-img_0424.jpg
Old Jun 25, 2012 | 01:14 AM
Revcore66's Avatar
I haven't actually replaced one on an f body but I've done quite a few on other makes and repaired quite a few too. Just from looking at your pics, it doesn't look too bad. I would probably have it repaired over replacing it. There would be a fair number of spot welds holding it on. It may have to be spliced in at the a pillar. The door and fender should really come off. And I'm not sure how it joins where it meets the front of the rear quarter panel. When a panel is replaced like that, it is more likely to rust on the inside where the new welds are, so it should also be sprayed with oil or wax oil on the inside.
Old Jun 25, 2012 | 04:58 PM
Rated Z's Avatar
thanks for your reply, the only problem about getting it repaired. They want $1400, when you scan by new for $50 and the paint for like $40.
Old Jun 25, 2012 | 10:18 PM
BLK95-Z's Avatar
You could fix that pretty easy. I bet it would still be $1400 to have a new one put in and painted anyway.
I fixed mine a while back and it was smashed pretty good
Old Jun 26, 2012 | 12:48 PM
yodas little brother's Avatar
that's a nothing job to fix.would take about 30mins to to the bodywork and primer.where are you finding new rocker panels??
i couldn't find any new ones had to buy a used one a couple years ago.
Old Jun 26, 2012 | 02:27 PM
Revcore66's Avatar
30 minutes? That is ******* funny! Good joke,
Old Jun 26, 2012 | 04:15 PM
ha no joke.if you feel like bringing it to florida i'll fix it for free!!!
looks like a couple little dings unless i'm missing something.
Old Jul 4, 2012 | 07:50 PM
Rated Z's Avatar
Where am I finding rocker panels cheap new? Ricks camaro.
Old Jul 15, 2012 | 08:47 PM
LilJayV10's Avatar
To replace the rocker you have to take part of the quarter panel loose because the rocker panel runs behind the quarter.
A 30 minute fix would be to fill it full of body filler and sand it down. Is that a hack fix? Not nessicarily, depending on how deep it is.
The "better" way is to pull it out then put a skim coat of body filler on it.
IMO I would do that before I would go through all the hassle of replacing the whole rocker. To do that you have to pull the door off, drill the spot welds out, mess the with quarter panel. That's a lot of a damn work for a part of the car you are really never going to see.
Old Jul 15, 2012 | 08:53 PM
LilJayV10's Avatar
I replaced part of the rocker on a 94 Formual I painted last year. Somehow the rocker got caved in pretty bad. Luckily it didn't go under the quarter panel.
Here are some pics.
Old Aug 20, 2012 | 09:14 PM
99camaroguy's Avatar
gonna take a little longer than 30 mins. I'm in the middle of replacing my DS rocker right now. It's a pain in the arss. Liljayv10 has the right idea though. cut that bitch at the quarter. I fucked up and pulled the whole thing off. It makes things alot harder that way.
