LT1 fender savers on LS1
LS1Tech Administrator
Received 1,493 Likes
This is very odd.
My '99, '00, and '02 did not come with these. And I bought the '99 and '00 brand new, so I'm very sure they never had them. I know that the '98s definitely came with them, and then they were dropped.
Did you buy this '01 car brand new? If not, then it's probable that someone has added them at some point in the car's past.
That's because it was a June build, if I remember correctly.
It would not surprise me to hear that some of the cars on the fringe of this model year would have already lost some of the items that weren't going to be on the menu for the next model year. This is also why some of the very late built '98s have the bubbling roof, because they were already phasing in the new process of omitting the paint barrier from the underside.
There are often overlaps and inconsistancies when it comes to the fringe of a model year.
Ah true, didn't think about that. Although my June build car was an oddity as it should have had the bad sail panel glue by then, but didn't. My 99 does of course
I may have to get a set of these fender savers for my 99 as my fenders are pretty well busted underneath already, but they would at least protect what's left of them and the tabs.
#34
It's possibile that yours may have been removed at some point. Or maybe the assembly line was sloppy with whatever part of the process included the install of this part, and thus it was missed on some cars.
#36
I wonder if this item was as hit-or-miss on the '93-'97 cars as it appears to be on the '98s?
#39
Dammit, I just double checked and all of my 98's have them. I should also mention that all 3 cars have had fender gap problems that required using pliers to bend the bottom areas of the fenders. In fact on the v6 car I broke the metal piece of the fender and had to bolt the fender into that plastic support piece this thread is about, so don't automatically assume that this piece fixes all the problems.
My z28 has a January 98 build date, the v6 is a 98 built in nov 97, and the formula was also built in jan 98. If I had to guess they were production pieces for the 93-97 cars that were phased out after the front end update but were used until the factory ran out
I should also mention of the 6 1998 fbodies that I have owned none have ever had roof bubbling, never had any cracked door panels
